  • 3 weeks later...
It Aint Pretty But she f**king hammers... RB25 in my 32
Oh and I decided to dummy fit the rear wheels... overfenders leave japland in 2 weeks, not long to go now and itll be 100% finished.
Dummied up the flare minus the overfenders obviously
All ghetto'd up with tape just to give a general idea of what she might look like when done, overfenders and finishing should make a big difference but you get the idea :blink:
By the end of the year the goal is to be putting down 600hp at the treads and to have all the cosmetic work finished.
Shit Camera. Ghey Sun. Clean 32.
Yeah very nice 32 man, luv those rims but what is with your camera? my fone takes photos much better than that... i'd be taking it back to the shop asap. heres one of mine (in progress) i took on the fone, getting rims soon then lower it and that will be it for a while before i go broke...
Here's a few photos i took today with a shitty point and shoot camera.
The front bar is off at the moment because of a little driveway accident. (driveway won)
Ive added a few pics of the damage to the front bar, if anyone has done this sort of repair before please pm me as I have never worked with fibreglass before.
Edited by FOG35
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
