hooray car is lowered!
I think its down to 340mm
Worried about the front as i have a feeling they might hit the lip if i turn wheel and hit a bump.. ^^,
Now i need to fit on the typeM skits/rear pods + spoiler and it will be all good :P
before:
and after!!!
rolling i can deal with, but not really keen on flarring..
Can you post a pic of a closer look at the flarring?
Also how low is your car from centre to wheel arch?
I think my shocks will drop the height to 340mm and hope i wont need to flare..
Thanks
oi i rekon those URAS's were perfect offset and size for the rear, looks real tough, u can either play around with the rear camber to slip them under or get the guards rolled, although i have to say, i didnt have any issues with mine before i rolled my gaurds, im running around -1 degree of camber. u definitely wont need flaring.
this is mine when i had those wheels before Rekin (17x8/9 +30):
now with some modenas which are soon to be sold aswell (17x8.5/9.5 +45/+38, fronts with 25mm spacers):
next on my list will be something around the 17x9 +20 mark which will sit out another 10mm at the rear from both of those rear wheels and a few mm further than where those fronts are sitting in the 2nd pic.
340mm is best height for r32 in terms of handling. Refer to sydneykid's posts etc for detailed information :whistling:
yep spot on, mine in those pics is the recommended height, using SK's GB kit.
yep I got SK's whiteline set up too
Just took car for drive, mine are scrubbing bad at front.
Any dips in the road and then you hear a creeking noise coming from the fronts.
Not sure if its scrubbing or perhaps the springs/shocks? as it seems to only come from the front right?
Guess its rolling lip on the weekend ~_~
Bummer dude, take the front wheels off and see if there is any damage on the tyres or body both inner and outer, i know that on a certian amount of lock my wheels touch the side skirts, on full they just tap the inner metals and over crazy massive bumps they might just tap the plastic under the guard... but ive got crazy stiff coilovers :(
Hey Rekin, I think your problem could be something to do with your shocks mate. Did you purchase second hand shocks and springs or new?
2nd hand kyb shocks with 2nd hand hks springs.
Perhaps i should get a suspension check done at Pedders?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
