now slam it with some spacers, de-wing and get that front lip your chasing
Looks real nice with the meisters on her. Should look even better once you add the front lip and remove the rear wing.
What size/offset did you end up getting??
why is everyone saying to remove the gtr wing? Im getting ready to put on a gtr wing on mine and now I cant decide! haha
Ive got 3 bootlids for my car; gtr bootlit w/ wing, gtst bootlid with wing and shaved bootlid with gt-wing
I guess i can swap around depending how i feel on the day :thumbsup:
gts4wd.... that was a good day.. shame bout the wind and the dust from the rally guys.. you were giving it a go.... good work!
Thanks champ! :P much appreciated
Yeah, For my first time out Im just glad i had a blast and left a better driver :)
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
