So since there are so many pumped GTSts and drift cars in this thread i thought best to post here...i now have faily pumped rears, by about 1" or so, ditto the front. Will 18 x 10 +22 clear with undersized tyres? Close? I know the 18 x 9 + 15 are going to be tight on the front, but i run plenty of camber which will help
when u say undersized tyres what do u mean? tyre size is one of the most important parts to wheel fitment so it's kind of hard to tell u without knowing that.
it also depends on how good the flare is (assuming thats what u meant by pumped and ur not talking about overfenders etc).
each flare is different and gives a different amount of clearance, regardless of how far it pokes at the furthest point. a lot of R32's have an issue with the wheel sitting further back in the rear guard, so even with decent flares they find the tyre starts fouling on the rear of the guard quickly.
saying that, 18x10 +22 should slide under fairly easy with a smaller tyre and a decent flare, few people are running 10" +20 on rolled 32 guards and a 235-225 tyre with a decent amount of camber.
R32 GTR of a friend
Anymore pics of this mate? are they 5Zigen FN01r-c's? have been trying to find pics of these on gtr's for ages, any idea what sizes they are?
Would love some more pics mate, thinking of getting those for me r33 gtr.
You're right mate those rims are 5zigen FN01r-c's :D Sizes are: 17x9,5 and 17x10,5.
Only got this single pic left, I hope it support's you on your decision :angry:
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
