looks LHD (look at the wipers). america? cali/florida cos of the clouds on the rego plate?
Hi guys Roy and Basti! It's from Manila. And yes it's a converted LHD GT-R. :) Our local laws don't allow us to drive RHD cars unfortunately. :)
Edited by GodziRRa
