This is my 32 had it for about 5 years now its almost there done a 2jzgte conversion that been in there about 2 years getting ready to do a E85 tune hoping to get close to 550hp at the wheels
Well got the big girl tune on E42.5 the other week and pumped out 525HP on 22PSI and 629nm of torque wanted to go 24PSI but was blowing spark out it went 540hp on 24PSI but yer spark issues
Fave pic! (Thanks finally Rhys)
PS, anyone know what front bar it is?
that is a trust front bar i belive. they are avalible off ebay according to my mate who has one. similar but subbtly different to the GTR bar.
Congratulations to the guys whose R32s made it into the R32 GT-R 21st Anniversary Celebration article in the current PI Mag #133.
Rego Plates include...
* GTR.32A
* YDU.43N
* GTR.619
* TUFGTR
* YGA.64Z
* GTR.32G
* GM45TR
+ others whose plates I can't see :thumbsup:
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
