Haltech, oem BOV's, a re-tune, driver/passenger windows and a engine bay detail this weekend ? OK
sounds good. Ill drop it off on saturday and pick up sunday?
Also prob am detailing this weekend
Yeah mate for sure, when I get back from the states later this year we should get them all together
Definitely! Always good to meet fellow 32 GTR owners.
The gtr in front is mine and behind is my brothers which is a Scuderia gtr. 1 of 6 and his is compliance number 001. Has standard n1 front and rear lip with snorkels, scuderia boot badge, scuderia instrument cluster and scuderia compliance plate as the car came to aust as a low volume import and sold here back in 89, via scuderia showroom in Vic. This is an old pic taken in 2004.
That is so cool that both you and your brother own Silver R32 GTR's!
Tiits and Ass, Titts and Ass
What are you up to Matty T ? A quiet SOB most of the time lately :P
Lurking mate, just lurking, i am a quiet SOB of late :P
Awaiting Container "A" to arrive, so i can have my goodies from our friends in Japan. That and i should see if my manifold has been started too, then i can get into swinging spanners and taking the TD06 kit off......but as im going to be moving soon, i would prefer to keep the car in a driveable state (well, drive on drive off the trailer anyways :laugh:)
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
