You can afford to raise the height of the car, easy fix for clearance
She drives really well thanks Bobby.
There's a li'l bit of scrubbing on the front tyres, so I'm thinking of lower profile or rolling the guards (which I've been told not to).
I think we might meet at some stage time/commitment permitting.
Again, thanks to all of you guys for support - the more warped it is, my humour appreciates it.
I run the 255/35 on the front. Mine are rolled.
Honestly Terry I'd have the front slightly rolled.
If it's the original paint and guard warmed before rolling there will be no paint flake.
(Resprayed guards and doing them cold will cause that crack and flake to happen)
Thanks for your input to Mick.
So it looks like...
1) tyre change to 35 profile
2) source progressive springs to suit Bilsteins > raise car
3) yet to be considered > guard rolling
Terry showing off again
Clicked over 50,000Kms today.
Even as a kid, I used to love things that glow in the dark.
One of the things I'd purchased before receiving the car, thinking, "What do I need a glovebox for anyway?"
Not sure if I'll be looking over to the left that much though...
  • Like 1
The rack Richard makes it (the R32) feel heavier than what it is. Or the corollary: the R34's rack makes it feel lighter than what it is.
Yes I like its 'rawness' a great deal. The R33 (which was my first GT-R) had a bit more oversteer which I actually liked.
I'm glad that I have upgraded the brakes, rotors, brake lines and castor rods on this R32.
Very well behaved. This is my 5th GT-R.
The 35 profile tyres have now eliminated scrubbing (compared to 40)
Thanks for asking :)
another N1 with A/c in it
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
