hey pete, I can get yours to play, but not the one of me or the kaki (keeps saying corrupt data) what codec did you use to encrypt?
several of his did that for me...i downloaded all the 1's he had up tonight, which was quite a few, and 50% of them were corrupt :)
  • Replies 224
Posted Images
Ryan!!
I know you have alot of footage :D
I do, about 11gig of DECA. ill try to get some done for the next meeting. i have made one compilation, but its poor quality. ill see about getting it posted. the rest will probably be edited for later on.....
hmmm how do you guy change the car to first gear when the car is moving so fast ? after watching a few vids it looks like thats whats happening... in my car i can only do it if im going like 15-20km/hr ????
WE ARE BRUTAL AND MERCYLESS ON THE GEARBOX :O
With enough force it will go in ;)
rev match it dude... will slide in easily then.
DECA = 0% mechanical sympathy
then you can put it in any gear you want, any time! Check out my "hooge dirt to dirt slide" in car footage at http://skylinesaustralia.vidiac.com and check out how many times I got from first to 2nd and back. Whilst going sideways!
hehe ya it was mainly you i was talking about :)
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
