I am more of a meguirs man, however my friend that details porchse GT3's and some of the cars for Joe Crisafio as mentioned in another thread, when polishing he uses 3M brand, the same people that do those sticky notes! apparently they have a small range of polishes aswell, though he does prefer meguirs car polish he said value for money this 3M car polish is real good. He used it on my car and seemed to come up sweet!
  • Replies 45
Hey, Gradenko.
I thought it was just me
But then I began to think
Perhaps its his IQ that's higher
'Coz maybe he is a literary type
Using word patterns and structures beyond your hype
Or maybe he is a technology tryer
So, careful to what you let yourself sink
Grammar Police, ... well ... maybe!
Cheers.
P.S. The sentiment is fine, but watch your own grammar too: "well constructed sentences IS ...". Ahem. Perchance this should be "are". And "sepArating".
Let he who is without sin cast the first stone!!
Off thread I know, but hey .....
Bugger, isn't it always the case. In future, I'll proof read before putting the smack down :(
Lets let this rest for now. Back to car cleaning!
Not sure where's the best place to get it.... i think (good automotive) paint shops... My old man picked this stuff up when he bought his Hilux, and has hardly used it....
http://www.ssindustries.com.au/consumables.htm
Looks like the above URL might give you an idea on where to get it....
Sweet! looks like industrial car cleaning heaven! I wil check it out!! thansk dude!
Use white spirits to get Amourall off the interior. Don't think you should use too much, I only did a small hidden area so I could stick my turbo timer on under the dash. Didn't notice any discolouration.
Just told today by someone that professional car detailers use a capful of kerosene in a bucket of cold water to wash black cars. He used it himself for 12 months on his black Landcruiser, and it did not do anything to the paint. No streaking, water marks or anything. Has anyone else heard of this?
I heard this before also never tried it but -- anyhow if it doesnt work just mix in the orange juice for a good night
Originally posted by GTS-t VSPEC
Does any of that stuff to keep mags clean work? I get alot of brake dust, don't know how:p, and they need cleaning every 2 days.
See'ya:burnout:
I use to live in the bush pretty much and travel to work everyday via limestone track with my VC Commodore, 17' rims, yadda yadda yadda... and mag cleaners are really crap, i use to clean my rims with turtlewax car wash, and then use a ... yes... silver polish cloth...with polish to clean them up spick n span :D
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
