  • Replies 242
I get usually anywhere from 380-420k's to a tank, fill up around 3 times a fortnight, mostly freeway driving, but still quite good regardless for a 350rwhp car. 320ks has been my lowest ever tank because it involved 2 cruises & 3 days. :)
https://www.sau.com.au/forums/topic/120328-fuel/#findComment-2217977
The GTR tank is spose to be about 72L, but when I fill up I put $70 in which fills it up quite full. $70 = 46.6L, is my tank smaller or something???
I usually manage about 380k's, 90% of that is peak hour traffic. I got 430k's a few weeks ago, I was quite proud :nyaanyaa:
https://www.sau.com.au/forums/topic/120328-fuel/#findComment-2218512
Damn $70... I only spend on average $55 a week
https://www.sau.com.au/forums/topic/120328-fuel/#findComment-2218629
Oh how the hell do you guys manage so many km's out of a tank? I get about 250km out of a tank of BP 98 and I have to fill up twice a week. 50% of driving time is open road and the other half is in the city.... :nyaanyaa:
https://www.sau.com.au/forums/topic/120328-fuel/#findComment-2218697
i get around 450 a tank in my gtr ..
Tom yes a gtr tank is 72 litres but there is asort of air pocket in them the most u would ever be able to put in them is about 65 litres
i can only fit 63 litres in mine if the low fuel light is on
most weeks i use around 80 bux for fuel (over 10000 k's since i gotthe car in January)
https://www.sau.com.au/forums/topic/120328-fuel/#findComment-2218875
Hey Nastazia...is the tank empty though...ie when you fill up how many litres can you squeeze in? Reason I say that is the fuel senders in the 33 can be a bit dodgy sometimes and give a false reading. Should definitely be getting more than 250km in a fairly stock skyline.
https://www.sau.com.au/forums/topic/120328-fuel/#findComment-2219435
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
