realised my o2 sensors were fitted but the plastic conectors were not hooked up. Now they are hooked up the car seems to run a little better and I am hoping the km's/tank will go up a little. Just filled up today 65L of the good stuff... lets see how long it lasts.
https://www.sau.com.au/forums/topic/120328-fuel/page/9/#findComment-2672284
  • Replies 242
Interesting..
Ive allways gone BP Ultimate in my import cars but I have heard this about Vortex 3 times now..
maybe we should do our own little mythbusters style test and see how it turns out..
Vortex Vs BP ultimate..
i found that i can get a few more k's outta vortex but watch the pinging increase. not worth it ! i think vortex is only 95. will only use it in the middle of winter if i need to. think the vortex 98 is even better than bp98 but dont sell it over here :P
https://www.sau.com.au/forums/topic/120328-fuel/page/9/#findComment-2675927
hmmm im going to have to fill up the tank in the zed and try this cos she drinks fuel like nothing on earth - thought she would be better than the Skyline but seems to be the same. On her little information dial thing she reckons she's getting 7.8L per 100 ..... which is like corolla fuel useage and she certainly drinks more than that .... maybe i just didnt see the 1 in front of the 7 ..... cos 17.8L per 100 would be far more accurate in my opinion.
https://www.sau.com.au/forums/topic/120328-fuel/page/9/#findComment-2702791
Niz, you can work it properly with the trip meter. Completely fill it up and reset the trip meter. Next time you fill up take down how many liters you put in and the KM's you did and work it out from there.
Its something like Liters * 100 / kilometers
https://www.sau.com.au/forums/topic/120328-fuel/page/9/#findComment-2702843
i managed to finaly get 400 km out of a tank on shell premium, yeehhhaaaa.
pity its only 95 octane
ihave heard shell and caltex have made an arrangement with bp ( the only fuel supplier in W.A.) to carry 98 octane
so it looks like no matter where we buy our 98 octane it will be bp ultimate just re labeled either shell or caltex
https://www.sau.com.au/forums/topic/120328-fuel/page/9/#findComment-2704119
well i filled up yest morning 400 k's 65 litres works out to 17miles per gallon pretty good figures for a gtr running 1 bar boost with 3 inch front and dumps into hiflow and 4 inch cat back and pods
https://www.sau.com.au/forums/topic/120328-fuel/page/9/#findComment-2704279
I'm lucky to get 350km to a tank running 7psi all the time. I'm gonna try some injector cleaner and might try cleaning the sensors. But I'm in the city the whole time and my foot is quite heavy so I don't think I'm doing too badly though. Tell you what, it's a shock after driving a charade for seven years! I used to get 500km to a 35L tank of fuel doing the same sort of driving. 600km if I was doing country runs.
https://www.sau.com.au/forums/topic/120328-fuel/page/9/#findComment-2704392
I do hwy driving but also stop start driving and get about max. 580km out of the tank, but average is around 530km with the fuel light just coming on and takes 55 litres its a 65 litre tank.
Thats with a little bit of lead footing as well so its not bad for such a powerful car other four cylinder cars I have owned only get like 650km so the extra couple of dollars means nothing for the performance enhancement.
I run mainly Vortex 98 or V-Power - Haven't tried the V-Power Racing as yet only because every shell i pull into I can't seem to get the bowser with it, but anyone know if putting that ethanol blend in the skylines is bad? As I have heard different things and not sure whethers it a good idea to try or not.
98 R34 GT-T Sedan.
Edited by lanky71
https://www.sau.com.au/forums/topic/120328-fuel/page/9/#findComment-2705167
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
