well you fark knuckles! I never had this problem before. but the now it's occaisoinaly started happening. I blame you guys and your thread!
going to try some earthing etc. see how I go.
  • Replies 212
it's actually a computer virus I have written for the PFC - that is spread by reading this tread :P
you bastood.
some more info if it helps.
I'm running a BCNR33 RB26 PFC in my BNR32 GTR. It's firmware is version 8.04a (latest firmware) and is not reflashed. It was tuned by PC (using datalogit from memory). running with O2 feedback on (and at least 1 faulty sensor, the other one i'm not 100% if faulty or not).
tune is excellent. car is currently making 270kw atw with 1 bar boost. also running splitfires coils, and NGK copper plugs (BCPR7ES gapped at 0.8mm).
you bastood.
I have my O2 sensors off - also have ~270atw with splitfires and copper plugs
same firmware
I pulled mine apart on sunday to have a look. Mine had a ground wire which was screwed onto the top of the transistor (ignitor pack thingy). the ground wire is connected to somewhere I cant really see as it was wrapped in a cable sheild with some other wires (but I believe its connected to the negative side of the battery. I just cleaned off the rust of the screw and the wire connector and since then i have had no missfires. Before this the missing happened at least once a day sometimes 2 or 3 times. But will have to see if it does it over a few more days.
i have had this problem too, ive located it to a faulty tps switch, it drops out and gives flat spots just on low throttle. very very intermittent.
btw 60 knock is regared as an "event" 20-40 is acceptable i believe. ive never seen more than 40 and only on decel, never on acceleration.
so - a new tps ?
Its like a curse., F%$K Y&^...noticed it the last couple of days on low RPM cruising along.
Why did I look for it.?????...could have had the stereo vibrating the car and would have never noticed.
My cover is off ,,,I have a PFC, Splitfire coils and the ignitor pack is not attached to anything.
Some-one please post up a quick fix with some wiring info......I have nowhere to fix it to.
If you don't I will put a Hex on all your cars :ninja::dry::D
OK Then....here is a quick mod. I have completed today to see if it stops the missing.
One fixed point........the other a cable tieing up 2 other points and fixing to another point.
The wire is thick on the second....and no movement at all.
So far tonight had no missing.......infact car is running smoother. :P
If it happens again...I will replace tps.
  • 2 months later...
Did a simular thing to my R32 GTR recently. Ran a ground directly from battery negative to transistor module. From transistor module to both rear and front coil pack mounting bolts. Also cleaned paint off mounting pads for transistor module. To date, no missfire. Blooody unreal, all sorted. :sorcerer:
Had the same problem with mine. Checked the earth on both the ignitor and the coil packs and found both had loose connectors. Soldered the connector to the wires and misfire has gone. Also problem only occurred once i took the cam cover off.
  • 3 weeks later...
I get this misfire once a month on average. It feels ike the engine just skips a beat, I thought the timing belt was slipping the first time I felt it :)
My recent re-tune brought my knock level right down. At start up it jumps up to 80, but once I reset it and drive, even with a cold engine I rarely see knock over 18 now.
  • 2 months later...
you bastood.
HI THERE. MY R32 GTR HAS THIS DAM APEXI MISFIRE ALSO. WHAT I HAVE NOTICED AFTER HAVING THREE SETS OF O2 SENSORS INSTALED THAT ONE OF THEM WILL ALWAYS SHOW THAT IT READING JUST ABOUT ZERO IF NOT ZERO VOLTS WHEN THE CAR IS WARM OR HOT, FROM DEAD COLD START YOUR CAR AND HAVE A LOOK AT YOUR HAND CONTROLER AND KEEP AN EYE ON THE O2 SENSOR VOLTAGE WITH BOTH OF THEM TURNED ON AND SEE IF THE NUMBER TWO O2 SENSOR STARTS TO LOOSE VOLTAGE AS THE CAR WARMS UP. WITH MINE IT IS ALWAYS THE NUMBER TWO O2 SENSOR ON THE HAND CONTROLER. THE NUMBER TWO O2 SENSOR ITSELF IS IN THE POSITION CLOSEST TO THE FRONT OF THE CAR.
I HAVE ALSO NOTICED THAT THE MISFIRE IS THERE WITH THE O2"S TURNED ON OR OFF. I HAVE HAD MY CAR TUNED BY 4 DIFFERENT TUNERS TO TRY TO GET RID OF THIS MISFIRE AND NO LUCK. CAR RUNS A NICE POWER OF 384.4 HP AT THE WHEELS.SOME SAY THAT THE APEXI IS THE WAY TO GO BUT FOR MOST OF US WITH R32 GTR,S. ALL THE BEST
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
