Im looking at selling my R32, but will only part with it for the right money. (Tell me what its worth by making an offer)
More than anything want the car to go to a god home. :D
Description.
- 92 R32 GTSt with 138,000kms (arrived in Aus with ORIGINAL 70,000kms)
- 17x8 rear, 17x7 front AVS wheels
- Complete Whiteline susp kit, including adjustable swaybars, front & rear strut braces, Bilsteins, alignment kit, bushes, etc, approx 12 months old.
- Hicas has been removed by way of chrome moly rear brace
- 330 x 32mm slotted front rotors , approx 9 months old
- Braided front & rear brake lines, all four calipers rebuilt with new seals etc only 2 weeks ago
- Rebuilt master cylinder & brake booster
- HKS Hyper exhaust
- HKS Air filter
- HKS front mount intercooler
- New Remote Filler with braided lines
- New 19 row oil cooler with braided lines
- Blue screen Apexi AVC-R
- New Bosch 040 Fuel Pump
- 5 puck clutch and aftermarket lightened flywheel
- Panasonic CD Player, matches Apexi boost controller, 5V outputs with sub woofer control, with Rockford 4 channel amp running 4 Pioneer 6x9 speakers
- Momo steering wheel and Nismo gear knob
Car is of course 10 years old, but still impresses with general conditon. Only body imperfection is in rear quarter, and is only a small dimple. Boost has been run @ 1 bar approx 15 times, due to pinging the AVCR is left off and used as a real time readout.
Car does see track use, but is mechanically good, compression test in December saw engine compression good across all cylinders, with vaccuum being consistant across all cylinders, if not a bit low.
Car never misses services and is always well maintained,
Welcome to inspect vehicle if your offer is genuine. Main reason for selling is car is in too good condition to butcher for serious track use, will be replaced with another R32 with rougher body.
http://www.skylinesaustralia.com/forums/at...s=&postid=63627
https://www.sau.com.au/forums/topic/12213-92-r32-gtst-fs/
I still have the OE intercooler and plumbing so wouldnt be looking for trade with cash adjustment, just straight sell. What $$$ would you be offering.
My bar has a mesh grill so the cooler is dent free and after a quick clean and polish could be mistaken for thinking its new.
https://www.sau.com.au/forums/topic/12213-92-r32-gtst-fs/#findComment-229258
  • 4 weeks later...
a good idea selling some of them seperately
Yeh but i think because of the kms, people wont even consider the car less some parts.
Maybe if i bolt in an import RB20DET (thats no better then whats currently in it). Catch 22, i put in new engine which is unknown quantity and could be worse then what i know to be a good reliable engine.
... plus new engine and people think car has been thrashed, you know "RBs last much longer then that... its been thrashed, i can tell":D
Ill see how it goes, but if people are willing to make reasonable offer on parts, then i will consider them.
https://www.sau.com.au/forums/topic/12213-92-r32-gtst-fs/#findComment-279944
Yeh the bar is factory, or should i say was factory. I spent hours cutting and filing to allow for the cooler pipes. Easy job, just have to be patient.
lol. everyone wants to canibalise my poor car. What $$$ did you have in mind for the wheels?
https://www.sau.com.au/forums/topic/12213-92-r32-gtst-fs/#findComment-280012
Looks very nice, but you'll need to find an R32 enthusiast to prick it up, cos all these generic p-platers are all lookin for r33's. To be honest, despite the mods, after bargaining i'd say you're lookin at bout $16 -17g. Best to rip some mods ( cooler, avcr, etc...) but keep the zorst, pod, and some of the system, should get some good cash.
K's are a bit over top, from a buyers perspective, i know this guy sellin a mild modded r32, couldn't get $13200 (advertised) a couple of months ago, now ads for $12g cos 125000k's....
I'd be very happy to take it off your hands, but wrong state, over my current price range.
Good luck!!
https://www.sau.com.au/forums/topic/12213-92-r32-gtst-fs/#findComment-280030
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
