finally my baby is here picked her up on thursday from the fremantle docks after a jump start from the docks guys and then a battery from RAC when I stopped for fuel and forgot that she wouldnt restart. After the hassles of getting a new battery she was away and running. I am so happy with my purchase and here are some pics below before I washed her
yeah the wheels have a fair bit of gutter rash and salt corrosion on them however they will be fine for track days and I will be getting a new set of rims asap to go on the car.
Yeah tangles I didnt realise how close it was till I was actually on the grass but hey gotta do my bit for the environment wash the car and water the grass
  • 4 weeks later...
Here's a shot from the SAU-NSW photoshoot day, most of which is appearing in HPI magazine issue 73.
My car was one of the few to miss out in the article, but Wil was good enough to post this up in our member's section.
I can't wait to lower it now, considering how good it looks even with the standard wheels! Who needs a body kit?
Thats a very nice photo. I like it!! :(
The front bar is a dayz bar with the standard lip on it by the looks of it?
That's what I thought Ska but have a closer look at the bottom bit of the bar, it is a different shape to the Dayz, def Dayz across the top section though...
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
