i like those side skirts, where did u all get them from and can you send me some in NZ :P
Talk to member AMS ......
Cruisliner, looking good mate. Hope the engine goes all ok with the tune. With the autronics ecu, why not call Brett West here in Marion SA at Adelaide Performance Engineers (sa Autronic dealer) and ask for advice, re attessa?
ummm - too keep me on topic, here goes :(
I dont think ive posted here yet!
Strange for me. Anyway heres my latest pics:
Bling.
Nice!
I absolutely love those wheels! They have to be the hottest factory alloys I've EVER seen. I'd love a set of those for my car - maybe get two sets so I could have the same size front and rear (so as not to upset the ATTESA, even though I could compensate with the correct tyre width and profile choice), and either sell one set off or keep them as spares for track days or whatever.
350GT wheels FTW!!!!!!111!!!!!
i do believe it is a dayz wing...
and the wheels are 18x8 all round so no need for two sets!
Cheers!!
I like the wing as well...
18x8s all round? Really? I thought the V35's with these wheels came with 8" front and 9" rears. Maybe you got lucky! Did you buy them, or were they on the car already?
i bought them from a mag shop, someone must have upgraded their v35 to 19" chromes or something as they had these wheels and some 350z wheels there. The 350GT probably doesnt need wider than 8" wheels really, heck the stag has heaps of traction on them.
Pretty sure these are all 18x8
What's the go with covering your rear lights on the door and the yellow plastic where the chrome should be next the the rear number plate?
Dont know if I'm a fan or not of the blacked in headlight surrounds - still it looks good on yours - I must be too old, from the era when too much chrome was not enough!
Not sure, i thought it was all normal. Another dayz option perhaps? I know the carbon lights are extra. Not sure if chrome would really suit the yellow paint.
Gor, Niiice. What suspension has your wagon got? What center of hub to gaurd has she got? Does it bump steer/ hang off the bump stops?
At the moment it has dobi sport springs from laurel/cefiro. They are too low all around as the front has 15mm rubber spacers and the rear has shortened shocks. It hits bump stops quite a bit and is generally a bit of a pain.
Thats what i get for paying a mag shop to "lower" my car i guess.
Unsure of the measurements of it all but the back has about -2.5 -> -3 deg of camber and cant really be udjusted out much as the wheels will foul on the guards so ill have to roll the guards at some stage.
The stock ride is much nicer, but doesnt have the boy racer look.
Dude are you up early or late?? 5:30 am sunday??? wtf anyway very nice ride!!!
Nick, As for what you said about upsetting the attessa system with different width wheels that is incorrect, it only has to do with different heights, not widths.
Bling.
Thats a smick lookn car you got there Logan!!!!! :O .......Was trying to get a yellow Stag too but luck provailed and ended up with the silver. Only a month to go and will have some pics of mine in the raw! Keep you all posted...... :O
Yeah I know, Simon. I was referring to how having different widths would require different tyre profiles front and rear, so you can get the same rolling diameter... I've always preferred having the same size all around - saves you carrying two different spares (not that there'd be room in the spare wheel well of the Stagea, but old habits die hard).
All good :O
I just use the space saver I get a flat.
Working under the notion that not too many KM's with it on should be OK.
On another note, how would the space saver affect the ATESSA with the notion that the Stagea has open diffs front and rear...
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
