You're going to have to explain the lights on the dash!
Finally the Police department has learn't that there current cars are crap and have made a radical change in pursuit cars! :P
It looked so nice after the wash so for $hits and giggles I wanted to see how it looked with the strobes fitted.
Must say, suits it well!
Hi guys,
Ive had my stag for about 4 months now so i tohught i should put some pics up. Its a wc34 s1, 125,000kms, auto, running 10psi through a neo turbo, fmic, 3in exhaust with split dump, tein coilovers, 20x9.5in koya wheels and other bits and pieces. Let me know what you guys think :)
No... lol The flexis after the downpipes are frayed, big centre muffler is split open like a coke can, front steering rack is now as course as 10 grit sand paper, rear diff has bits taken out of the bottom and my headlights keep coming loose from hitting bumps.
It's not fun on the open roads, well sometimes it is... Like when you can pick up a flattened hedgehog you know you're low, or smashing a beer bottle that's lying down lol
lol @ flattened hedgehog.
Could you imagine if you were clicking down the freeway @ 110, and came across a dead Roo that you couldn't avoid!?
When I was an apprentice with the Railways, I used to have to clean dead animals (roos, cows, sheep) off the underside of Locomotives, not fun.
Still, at least I didn't have the experience of one of the other apprentices; he found a human leg...:O
Lol. Dale, that's mad. Never short of a bit of jerky with an arvo beverage hey mate?
My first job was cleaning cat shit outta cages at a pet boarding place. Over 100 cats in at Christmas time. That's a lot of litter trays. sick.gif
Cleaning rotten grain spillage out of ships runs a close second.
Thanks guys, 30mm spacers. Wheels are v35 PREMIUM wheels. and they are 18x8 +30. so atm its 0.
Will take side on shots soon, The car was fully loaded with my welding gear hence the lowness,
Speaking of which. Whos running really stiff springs on their m35s?
My car is bouncy as f**k and drops about an 1,5 inches when seated!!!
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
