You're going to have to explain the lights on the dash!
Finally the Police department has learn't that there current cars are crap and have made a radical change in pursuit cars! :P
It looked so nice after the wash so for $hits and giggles I wanted to see how it looked with the strobes fitted.
Must say, suits it well!
Hi guys,
Ive had my stag for about 4 months now so i tohught i should put some pics up. Its a wc34 s1, 125,000kms, auto, running 10psi through a neo turbo, fmic, 3in exhaust with split dump, tein coilovers, 20x9.5in koya wheels and other bits and pieces. Let me know what you guys think :)
No... lol The flexis after the downpipes are frayed, big centre muffler is split open like a coke can, front steering rack is now as course as 10 grit sand paper, rear diff has bits taken out of the bottom and my headlights keep coming loose from hitting bumps.
It's not fun on the open roads, well sometimes it is... Like when you can pick up a flattened hedgehog you know you're low, or smashing a beer bottle that's lying down lol
lol @ flattened hedgehog.
Could you imagine if you were clicking down the freeway @ 110, and came across a dead Roo that you couldn't avoid!?
When I was an apprentice with the Railways, I used to have to clean dead animals (roos, cows, sheep) off the underside of Locomotives, not fun.
Still, at least I didn't have the experience of one of the other apprentices; he found a human leg...:O
Lol. Dale, that's mad. Never short of a bit of jerky with an arvo beverage hey mate?
My first job was cleaning cat shit outta cages at a pet boarding place. Over 100 cats in at Christmas time. That's a lot of litter trays. sick.gif
Cleaning rotten grain spillage out of ships runs a close second.
Thanks guys, 30mm spacers. Wheels are v35 PREMIUM wheels. and they are 18x8 +30. so atm its 0.
Will take side on shots soon, The car was fully loaded with my welding gear hence the lowness,
Speaking of which. Whos running really stiff springs on their m35s?
My car is bouncy as f**k and drops about an 1,5 inches when seated!!!
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
