Good time Dale and great shot....
Is that a baby seat in the back???
Cheers Jase; pretty stoked to get the time too!
Why yes; yes it is, dad spec is the new sex spec. The after sex spec, if you will. ;)
And given half a chance; my young bloke would've been along for the ride...
Josh, the 18 x 9.5 +12 fit all good? any guard work needed?
I run 18x9.5 +12 on my s1, with 10mm slip ons on the front, ive rolled my guards all round, although have quite a lot of camber, if your're prepared to go quite low, they fit well.
  • 1 month later...
Took a photo up at Mum and Dads today inbetween working on the Xk120. This is pretty much my safest ride height and where it will stay. 335mm front eyelid, 330mm rear. It clears up over any driveways, gutters and gives good enough travel over the shitty roads (I do alot of onsite callout's Tweed/Goldcoast).
Even though my exhaust is tucked up pretty nicely, it's lowest point is 110mm off the deck.
Car drives so well still for what is now 335,000klms on stock turbo no rebuilds. Been running 12psi+ for the last 200,000 klms :D Roil Additive at the start and motul 8100 excess every 10k. Have to credit Nissan for building such an outstanding engine, driveline - everything.
Pennies are being saved now for a couple more suspension parts - front tension rods and swaybars. The clutch feels tired so probably needs doing soon and then I can get onto the better stuff in life - hypergear turbo, injectors, fuel pump, z32 afm, cams and nistune.
Jez
Jez
looks good always loved these yellow stageas
looking good Jez!
Makes me keen to get new wheels and coilovers for mine!
Also, blacked out grille and highbeams looks pretty good too
Because it makes it look less like a Series 2 and more like a series 1.... HA.
looking good Jez!
Thanks guys !! Appreciate it.
It does change it up a bit. Got a bit bored with the pig nostrils ( thats what i call the high beams )
Just a couple of pics of mine from the SAUQLD Charity cruise.
Thanks to Andrew and Chris for the pics.
Car looks great SABBAi, how the hell did I not know about this charity cruise. I am such a dope some times.
might as well post a pic of mine...
got a late model front end & some 20" VSKF's coming in a container..
here is a photoshop mockup of what it should hopefully look like in a couple months
Edited by loz-tuned
    • That idea has crossed my mind, I do a 5km walk everyday, this does take me past some bushland......I think you may be onto something 😉  That, plus 1 rock on every bin night might do the trick, it may take a year, but it could save me a couple of grand The only issue is the big 'Boonies", I have a few that weigh around 30-40kg, maybe they should be the first to go into the raised garden bed,  and then let the next owner deal with them....my daughter gets the joint when I kick the bucket, mums the word mate......LOL Noice......
    • Wow. Did you call the car a Nissan Skyline?
    • You're retired Mark, on bin night, go for a walk, kind of like you're doing the beep test. Put one rock in the first neighbours, come back, get another rock, go to the second neighbours, repeat over many weeks. All rocks eventually gone...
    • No chop chop of anything mate, it is what it is, plus, I don't want any air that isn't either going through the cooling stack or intake getting into the engine compartment increasing under bonnet pressure  Yeah, the Mazda Speed aftermarket intake above is less than ideal for multiple reasons, the requirement to remove the bumper every time you need to service the filter, and also smaller in diameter than the NC1 OEM one Weirdly, Mazda Speed is part of the Mazda motorsport division, "form over function" and $$$$$ for Mazda from unsuspecting punters I suspect  After some googling about them it seems they added no power, but do increase some induction noise Meh In other news, the electricians have been busy today at the house, and are back tomorrow finishing up all the security stuff and exterior lighting, they also added some lighting on the garage ceiling, which will come in handy when working in the garage when it's not freezing out there My Birdies raised garden bed also arrived today as well, which I'll put together and place tomorrow, it's a big tall Bessie, 74cm high, 92cm wide and 214cm long, this will come in handy as I am starting to get "stockpiles" of good soils from doing landscaping, some of the clean rock, namely the river stone, will go into the bottom of the bed for drainage, as well as the old Apricot tree that was out the back,  and when it's full, I'll grab another one, I will be growing enough veggies to keep me both busy as well as supplementing the shopping list I'm also awaiting another quote for a new Colourbond front fence, as the "1980 style cemented in rock edging" that was there and "fashionable at the time" looked arse, and my god, the amount of cement used to fix the rock was insane, it took 1.5 days for me to break out 12 meters of the stuff by hand, trim the bushes back to the fence line and dump it out the back of the joint to deal with at a later date,I will soon need a skip bin to tip it all Unfortunately they did alot of the cemented in rock around the joint, which I hate, so a few pallets of retaining wall blocks for around the front and back where the cemented in rock is will be required to bring it up to a standard, and look, that I will be happy with 12 meters worth of rock and cement Finished smashing the fence line and ready for a fence to be installed, yes, the lawns need some TLC and thickness, the previous owner trimmed the grass to the roots 😢, the TLC I can provide, and nature over time will do the rest And there's probably about another 40 meters worth of this landscaping abomination left to do around the front and back gardens, I'm guessing maybe 3 or 4 tons worth, tip fees for this will be a killer Meh, all in all I'm having fun and keeping busy, plus, it's good PT
    • If I drove to a typical petrol station, what would my choices of fuel be?
