might as well post a pic of mine...
got a late model front end & some 20" VSKF's coming in a container..
here is a photoshop mockup of what it should hopefully look like in a couple months
Lights, grill and bonnet won't fit with the series one bumper.
ummm... you have no aero front bar right?
Thats a photoshopped pic of Bbennys old car. (I miss that car...)
your original pic doesn't show aero kit, so I assume you don't have it. Anyway- what these guys have said is correct. if your going to change, I hope you got lights fnt bar and bonnet. Hope it goes smoothly for you.
Yeah it's a PS of benny's car.. nice base car photos help for decent chops.
not sure if i want aero sides and rear yet, I have them here but wheels always look bigger with no aero, and don't mind the grey plastic finish.
i have the grille, s1 foglights front bar, hid lights on the way...
Am guessing the HID's should fit the s1 bar (no shape change?).. grill might be a little work.
Once it all arrives we will see how it all fits up- im not really a fan of getting a later model front bar unless it's the nismo aero, which might take a while to source one, so the grille might have to wait..
Edited by loz-tuned
Nice.
Edited by Jetwreck
Hey guys
heres my M35 ARX.
her mods are
HDI FMIC
dump/front pipe (scottys) and custom exhaust
bilstein/ nismo suspension ( jetwreck)
z33 nismo thermostat
blitz panel filter
saas boost gauge
brake cut mod
DBA slotted front rotors
QFM HPX pads
speedy cheetahs 19x8.5
faulkens 245/45
and as we speak in the post is scottys coolant mod and a plenum spacer..
tranny cooler and inline thermostat in shed ready t go
future mods:
front and rear chassis brace
mishimoto oil cooler
transgo shift kit
Edited by Footo
definitely. gave a place a call over here they can get the whiteline ones for me :yes:
What price are they able to do?
Even with postage, I'm generally cheaper than most dealers.
Might be able to slide a front brace in there too...
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
