I like it Rudi, something different/unique. Do you have a black roof? I couldn't tell from pic but it would look mad with wrapped gloss black roof
yep, wrapped black gloss roof, thats why i got the bonnet plus the vent to let the heat out. :yes:
All you need is a big black f*ck off takeros wing with a whale front bar and you'll be set!! :D
Also, needs moar nismo.
Looks great! The grille needs some doing though.
cheers, maybe a mixed grille and a beer? LOL :cheers:
  • 4 weeks later...
^rajab damnit!! :worship:
Took the stag camping, had a bit of trouble getting into the spot, shes a little low and stiff. Had her balanced on 2 wheels. Defiantly raising her next time...
10152458_10152272321873819_4516988919289
Edited by Dobo
  • Like 2
So I joined this forum specifically to come here and tell you all what beautiful Stageas you all have. I have never read through 112 pages of pure jealousy before!! I only wish I Could have a Stagea here in the US. But until I find a way to get one, I shall just live vicariously through all and contribute what I can!
Cheers!
  • Like 1
Cheers!
Are there no avenues for a personal import?
Honestly my friend,
I wouldn't be sure where to start as far as what I would need to bring one over, I know the US has the most obsurd import regulations. My R34 that I had was a complete nightmare, and as such I was never able to drive it for more than a year without have to re-register it to skate around emissions requirements, if it doesn't have the "correct" diagnostic port, they won't even test it. And also for me as of late, money has been very tight. I found one in Canada, a Black Autech 260RS. I would kill to own it, but they want A LOT for it. so until I find one cheap enough that I can afford to buy it, I figured I can just share My Stagea love here!! :) not unless you all want to send me one piece by piece through the post :P LOL
here's the link for the one I found, http://www.tyeeimports.com/jdm-cars-for-sale/japanese-import-car.asp?ProductID=897&Title=1998 -Nissan-Stagea Autech 260RS'>http://www.tyeeimports.com/jdm-cars-for-sale/japanese-import-car.asp?ProductID=897&Title=1998 -Nissan-Stagea Autech 260RS They are asking $13K Canadian, roughly $12K US. A little rich for my blood, plus US banks would never give a loan for a car that old :P
Edited by Godfoot
You have a slightly skewed point of view on the pricing of the Stagea.
If a 260rs could be had for that kind of money in Australia; wow. Double it; and then some.
Oh My! Well Then I need to stop being so poor!! :P I didn't know they were that costly in Australia!! Even more respect to you guys for working so hard!!
Everything is relative in each different country, not judging your own financial situation.
Welcome to the forum, it will be interesting to see whether more Stageas make it to the USA given the changes to import regs.
Ànd we would kill for the pricing you guys get on you're cars!
Luxo cars often cost double if not more in Aust compared to the US.
I know I'd jump into a E55/63 wagon if I was over there!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
