I like it Rudi, something different/unique. Do you have a black roof? I couldn't tell from pic but it would look mad with wrapped gloss black roof
yep, wrapped black gloss roof, thats why i got the bonnet plus the vent to let the heat out. :yes:
All you need is a big black f*ck off takeros wing with a whale front bar and you'll be set!! :D
Also, needs moar nismo.
Looks great! The grille needs some doing though.
cheers, maybe a mixed grille and a beer? LOL :cheers:
  • 4 weeks later...
^rajab damnit!! :worship:
Took the stag camping, had a bit of trouble getting into the spot, shes a little low and stiff. Had her balanced on 2 wheels. Defiantly raising her next time...
10152458_10152272321873819_4516988919289
Edited by Dobo
  • Like 2
So I joined this forum specifically to come here and tell you all what beautiful Stageas you all have. I have never read through 112 pages of pure jealousy before!! I only wish I Could have a Stagea here in the US. But until I find a way to get one, I shall just live vicariously through all and contribute what I can!
Cheers!
  • Like 1
Cheers!
Are there no avenues for a personal import?
Honestly my friend,
I wouldn't be sure where to start as far as what I would need to bring one over, I know the US has the most obsurd import regulations. My R34 that I had was a complete nightmare, and as such I was never able to drive it for more than a year without have to re-register it to skate around emissions requirements, if it doesn't have the "correct" diagnostic port, they won't even test it. And also for me as of late, money has been very tight. I found one in Canada, a Black Autech 260RS. I would kill to own it, but they want A LOT for it. so until I find one cheap enough that I can afford to buy it, I figured I can just share My Stagea love here!! :) not unless you all want to send me one piece by piece through the post :P LOL
here's the link for the one I found, http://www.tyeeimports.com/jdm-cars-for-sale/japanese-import-car.asp?ProductID=897&Title=1998 -Nissan-Stagea Autech 260RS'>http://www.tyeeimports.com/jdm-cars-for-sale/japanese-import-car.asp?ProductID=897&Title=1998 -Nissan-Stagea Autech 260RS They are asking $13K Canadian, roughly $12K US. A little rich for my blood, plus US banks would never give a loan for a car that old :P
Edited by Godfoot
You have a slightly skewed point of view on the pricing of the Stagea.
If a 260rs could be had for that kind of money in Australia; wow. Double it; and then some.
Oh My! Well Then I need to stop being so poor!! :P I didn't know they were that costly in Australia!! Even more respect to you guys for working so hard!!
Everything is relative in each different country, not judging your own financial situation.
Welcome to the forum, it will be interesting to see whether more Stageas make it to the USA given the changes to import regs.
Ànd we would kill for the pricing you guys get on you're cars!
Luxo cars often cost double if not more in Aust compared to the US.
I know I'd jump into a E55/63 wagon if I was over there!
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
