RB20_ZED Posted June 27, 2006 Share Posted June 27, 2006 To cut a long story short. Was driving today and the car seemed to accelerate without me making it. I pushed the clutch and pulled it into neutral and the engine reved quickly up to 9000 by itself and stayed there until i was able to cut the power to the fuel pump (luckily i have a kill switch). Im guessing that the accelerator cable got stuck but it seems fine and im worried that it could be caused by something else - maybe turbo/boosting related? I wasn't driving the car hard at all when it happened. what would cause the engine to spike to 9000 revs and stay there? besides the accelerator cable/pedal getting caught or stuck. my car seems fine now but im scared to drive it without knowing what may have caused it since the cable doesnt seem like it had anything to get caught on. any help/opinions would be appreciated. Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/ Share on other sites More sharing options...
Cool Hand Luke Posted June 27, 2006 Share Posted June 27, 2006 i've had a loose throttle cable slip off when the throttle was half open and stick like that, then be back in place by the time i stopped the car and lifted the hood. If the throttle body is closed, the engine cant rev. It has to be the throttle sticking somewhere Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/#findComment-2290029 Share on other sites More sharing options...
paulr33 Posted June 27, 2006 Share Posted June 27, 2006 throttle cable would be the only likely culprit i could think of. the throttle body would have to stay open for that scenario to have occured Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/#findComment-2290031 Share on other sites More sharing options...
The Dan Posted June 27, 2006 Share Posted June 27, 2006 As above.....twice. Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/#findComment-2290035 Share on other sites More sharing options...
RB20_ZED Posted June 27, 2006 Author Share Posted June 27, 2006 thanks both of you. just needed the reassurance that it had to be the cable somewhere or other. Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/#findComment-2290038 Share on other sites More sharing options...
R31Nismoid Posted June 27, 2006 Share Posted June 27, 2006 Or a hose. I had some hose get loose and get jammed in the throttle body. I forgot to use a cable tie after i was changing the plugs or something and it moved in the way. No harm done Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/#findComment-2290125 Share on other sites More sharing options...
Cubes Posted June 27, 2006 Share Posted June 27, 2006 wow 9k... I wonder what happened to the rev limiter. Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/#findComment-2290259 Share on other sites More sharing options...
Tough R34 Posted June 27, 2006 Share Posted June 27, 2006 drop the clutch and video tape your car going ballistic. Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/#findComment-2290272 Share on other sites More sharing options...
someonestolecc Posted June 28, 2006 Share Posted June 28, 2006 Just to be simple - your foot was off the accell pedal right? Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/#findComment-2290848 Share on other sites More sharing options...
PHATR32 Posted June 28, 2006 Share Posted June 28, 2006 the brake pedal is in the middle, not to the right.......... Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/#findComment-2290882 Share on other sites More sharing options...
RB20_ZED Posted June 28, 2006 Author Share Posted June 28, 2006 the brake pedal is in the middle, not to the right.......... smartarse Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/#findComment-2292608 Share on other sites More sharing options...
Kaido_RR Posted June 28, 2006 Share Posted June 28, 2006 what is your car rev limiter set too? as i know sometimes in the r33 it was set to 7100rpm and uses to bouce of 8000rpm for a second or two then come back down to 7100... Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/#findComment-2292617 Share on other sites More sharing options...
psybic Posted June 28, 2006 Share Posted June 28, 2006 Or a hose.I had some hose get loose and get jammed in the throttle body. I forgot to use a cable tie after i was changing the plugs or something and it moved in the way. No harm done Same. The hose. Was mid burn out, started getting out of shape, backed off.... hose says no. For reference, its not lucky you have a kill switch, everyone should be aware you can simply turn the key off, throttles getting stuck is not that uncommon, don't panic, just turn the key off. Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/#findComment-2292628 Share on other sites More sharing options...
C_DawG Posted June 28, 2006 Share Posted June 28, 2006 For reference, its not lucky you have a kill switch, everyone should be aware you can simply turn the key off, throttles getting stuck is not that uncommon, don't panic, just turn the key off. Careful with the key, too far and you will be dealing with the steering lock. Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/#findComment-2293193 Share on other sites More sharing options...
R33fourdoor Posted June 28, 2006 Share Posted June 28, 2006 Careful with the key, too far and you will be dealing with the steering lock. Don't you have to take the key out of the ignition before the steering locks? Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/#findComment-2293301 Share on other sites More sharing options...
R31Nismoid Posted June 28, 2006 Share Posted June 28, 2006 Or just go up a gear, 4th to 5th and jump on the brakes till you cna sort out turning the ignition off. Thats what i had to do as i wasnt sure what was going on. It isnt good for the car, but the rev limiter is there and does the job, but better than getting too outta shape. I'd rather f**k a clutch than have somethin bad happen Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/#findComment-2293307 Share on other sites More sharing options...
Dee 33 Posted June 29, 2006 Share Posted June 29, 2006 My story is good. The same thing happened to me. Nailed it at the lights and then the throttle jammed open somehow, car rocketed down the street, evetually switched it off and rolled to a stop. Upon inspection, the f**king trumpet from my GFB Bov had unscrewed, and jumped across the engine bay coming to rest under the throttle lever leaving it wedged fully open I made sure I screwed it on extra tight afterwards. Seriously though, what are the chances of that? Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/#findComment-2294265 Share on other sites More sharing options...
2rismo Posted June 29, 2006 Share Posted June 29, 2006 Kill switch is a great idea. No steering lock to contend with, no turbotimer issues. Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/#findComment-2294414 Share on other sites More sharing options...
**JaR** Posted June 29, 2006 Share Posted June 29, 2006 Don't you have to take the key out of the ignition before the steering locks? dont think so, if the cars off and you move the steering wheel to far to either side it'll lock it with the keys still in the ignition. Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/#findComment-2294434 Share on other sites More sharing options...
PHATR32 Posted June 29, 2006 Share Posted June 29, 2006 the steering wont lock untill you push the button and take the key out!!! Link to comment https://www.sau.com.au/forums/topic/124044-car-got-stuck-on-9000-revs-without-me-doing-it/#findComment-2294462 Share on other sites More sharing options...
