I'll be entering into the world of auto > manual conversion shortly. Was eyeing off an S2 stagea at the wreckers that had been converted. I have about 2 weeks to do it in, but shouldnt take that long as all the bits I need are there already.
I'll post progress & pics once I've started.
Nooch
Nooch
With some help its a weekend job. Only special gear is something to cut the hole for the gear lever and a welder for the handbrake bracket.
Thanks Bob,
yeah I should be ok. Only thing that will slow me down is I'm a bit limited by my mobility as I'm not fully recovered from an earlier accident.
I did print out all the info on the conversion + a few additionals that people had thrown in.
Slowly all my pieces are coming together, I cannot seem to spend money on one consistent goal, I am all over the place, I've got most of the parts I need for power, Then I got a 32 GTR box (bargain, couldn't resist), Now i've started buying more parts for my stereo, just got a bunch of gauges, I guess it doesn't really matter what order I buy stuff in because everything will be done in one go, no point doing one bit, then another in a few months haha.
I am interested to see what people have done with their auto consoles, I am Most likely going to just modify mine and make it work, are there much pics going around of modified auto consoles that anyone wants to share? Not fond of spending the kind of money needed for a proper manual console....
Hello fellow stag owners,
i bought a factory RWD stagea RS series 2 and its auto :angry: anyway ive got a r33 gtst gearbox sitting at my mates house and Im just wondering if it would be a direct bolt up job or do i need another gearbox? im not sure if its a series 1 or 2 gearbox.
ok thanks!
i havnt seen any forums for the factory RWD manual conversion so i thought i would ask. im running a haltech sp2000 ecu and ive got a r33 tailshaft and spigot so it should be all good! just have to gather all the other bits
Well I decided to let the guys at Top Secret handle this job for me and deal with the heat too. Theyll take care of the install of the box, pedles& handbrake. I could have done it all but its nice to know you have some sort of warranty on the install. Once this is sorted its off to get the zorst sorted.
Happy days
Can anyone clear up a bit of confusion over the flywheel for me. Got a 96 Stagea RS4 and looking at putting the r33 gtr box in. The guide says to use a 9 bolt style flywheel, but when helping a friend rebuilding a rb25det for his skyline yesterday I noticed that theres only 6 bolt holes for the flywheel. Looking at getting a lightened wheel so don't want to shell out a load for one that won't fit.
All RB flywheels have 6 bolts holding them to the crank - the difference is in the number of bolts holding the clutch cover (pressure plate) on. To quote Kudos Motorsport:
All R31/32/33 RB20/25/26 cranks use a 6 bolt flywheel to crank configuration, and the following pressure plate to flywheel:
•RB20E, RB20ET & RB20DE (225mm Clutch Disc) - 6 Bolt
•RB25DE & RB25DET (240mm Clutch Disc) - 9 Bolt
•R32 RB26DETT (240mm Clutch Disc) - 9 Bolt
•R33 RB26DETT (250mm Clutch Disc) - 9 Bolt
For starters awesome thread!!!
Doing manual swap soon gathering parts..
-What clutch should be used??
Im running it in rwd only... R32gtr box would a heavy duty organic listed for a r32 gtr work well? Thanks
-also r34 manual console work or not??
Thanks rob
1st up awesome thread!!!
started mine manual s1 swap today.. my contributions to the the thread:
-r33 clutch pedal is good fit BUT hole to bolt up to dash does not line up. r33 has 1 hole stagea has 2 holes... i cut and weld the bracket off the handbrake pedal.. otherwise two bolts taking pressures off the firewall..(very thin) not good idea
-r33 hand brake and cable PERFECT (besides mounting holes)
swap is on pause ordered a r32 push clutch, box turned out to be r32-3 pull but its goin well printed conversion guide out and reading it like a bible!!! thank you so much :)
  • 4 weeks later...
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
