why would you have a flare in your car :S
but since everyone else likes them ill buy some!
they're required in japan....im assuming you have an R33...look in the passenger footwell and you'll see the flare holder clips ;)
Most of them are gone when they get imported, or taken by guys at the docks/compliance etc....some are still there...Mine was there when i checked out my car at the compliance workshop, so I took it home before they got their sticky fingers on it hehe
yes it's for if your car brakes down on train tracks at night, or on a dangerous piece of road at night. when you light them they just burn bright red and smoke a little. no shooting or anything special.
They are removed at compliance.
I've got one in the GTR and GTST but I've lost the one from the soarer.
Anjo0, if you want to flog some i'll take 3. i want a spare for each car :O
Well there ya go, i only saw the holders yesterday, had the car for just over a month and thought the place where i bought it from had taken something out that should be there. I wish i had looked to see if it were there when i took the car for the first test drive!!!
i want a flare, care you buy them? im guessing maybe from a marine shop ro something
if anyone has a real "nissan" style flare i want!
my 33 has the holder but no flare when i first got my car i thought it was for a japanese fire extinguisher (smaller and more efficient then ours/us) :P
