hey guys ive tried searching couldn't find wat i was looking for
just wondering what fuel economy you guys get out of your r33
i dont get the best, around about 250kms>$65 bp ultimate around town
10psi
cooler
exhaust
walbro pump
5spd
could anyone else tell me if this is normal or bad?
https://www.sau.com.au/forums/topic/125582-r33-fuel-economy/
My factory stock R33 SII 4dr auto gives me an average fuel consumption of about 11.6 l/100km which is about 430km on a 50l fill up.
Any idea how that will change when I fit a 3" catback and K&N panel filter?
usually fill up around the 1/4 mark, bp ultimate, 3"exh, pod, FMIC and on 7-8psi, getting 300k, also depends on driving. Mostly m4
Just had a major service, installed exh cam gear and EBC so will see how it goes now!
Do all R33's have fuel lights? Never had mine come on but have had it near the line!
the light will turn on for about 5 seconds then turn off when you get in the middle of the line then it will come back on and stay on when you have about 10 litres left i think.
You get plenty of notice on a r33 (so im told) ive done 30 ks when the light came on and turned off again
maybe i will test it, i have never seen it come one when i have run pretty low, but then again the fuel goes down and comes back up a bit again, not 100% accurate!
10psi
cooler
exhaust
walbro pump
5spd
I get about the same. Around town, havent really been pushing it. 5spd manual, similar mods: cooler, pod, exhaust, 11.5 psi
$70 ultimate got me 270kms last time round :\ gonna get it tuned so it doesn't run as rich, then we'll see if it improves.
ah you have plenty of time even when the light goes on... you can get a fair way down under the 'E' line as well... its only when you turn a corner, get on the gas and it misses and splutters that you need to fill up LOL
Ah come on dude. You didnt even have to search, dont tell fibs :nyaanyaa:
Its all in the sticky thread (Forced Induction Guide)
Here are some links for you to have a read over
Guide itself:
http://www.skylinesaustralia.com/forums/in...showtopic=66556
And related links from the guide:
http://www.skylinesaustralia.com/forums/in...showtopic=43095
http://www.skylinesaustralia.com/forums/in...?showtopic=2879
Cheers :rofl:
R33 - pod - 3inch exhaust - plumb back bov.
I only got 380kms out of 50litres, and 200kms of that was 5th gear freeway kms.
I'm looking at about 250-300kms per 50litres city driving.
I drive it easy, jump on boost quite often, standard skyline behaviour.
Changed my O2 sensor last week. Has made no difference at all.
The way I see it, you want performance, it's gonna chew up fuel.
On the other hand, my mate's FPV F6 turbo goes through a tank every few days. Now that's crazy.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
