I'll see the "good boys" at the park then :P
Biaaatch, you gonna wanna better bring that Baby past here first. :woot:
Is grevillea park the one where we use to meet before we went to marquee in the park or Shannon's near the paddle boat hire place
Not sure on the comparison but it's down near the BoatHouse Restaurant.
Check out the mappage on the first page... :thumbsup:
Hey guys,
A few of us are planning to go to Dickson tradies before hand for dinner. Feel free to join us. We will be there by 7pm. If you can let me know that you are coming, I might book a table.
ANU worked out for us last week. So we (the people that were out there last week) will go back there again, unless there is a issue with the carpark or security asks us to move on. I highly doubt the police will be called because we don't look like a group of car people.
Bought it from Victoria? Does that mean you have to go through Dickson again?
Yep - back through Dickson. It's fairly stock already. I got all the stock parts in the back seat except the exhaust. He is posting it.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
