Any graph to view? The outright power figure is very impressive for the boost you've run.
How are you finding the 56T / VG30 combination in terms of streetability and response with the 2.4 litre capacity?
  • Replies 121
i will get a graph once i get the tune checked over, i havent got one printed since the headgasket was changed. but had a quick look at the run he did and it had 12psi by ~100kph in 4th.
actually it feels really good, mind you i havent really tested it properly as i'm abit unsure how healthy the tune is, but the rb25 housing felt better in regards to response but had surging and boost spiking issues.
but SR20s spool turbos better than rb20s due to their longer stroke
what is the compressor and turbine A/R on the hks GTRS?
currently im really keen on the GT2871R highflow cos it all bolts up, and from what i hear, the exhaust A/R is 0.63
HKS unit has comp .60A/R, turbine .63A/R.
A carefully thought out high flow can work very well, but the apparent aims of factory engineering needs to be factored in when using factory-spec housings.
In some respects I'm not massively surprised that kwazza11 had troubles with surge with the 56T comp and 2.4 litre capacity. My calcs for the RB25 suggested it would be borderline, depending on the power target. Using the VG30 turbine housing is a way of masking a technical mismatch and still getting a satisfactory overall performance characteristic. If the compressor is not excited as easily due to the higher flowing turbine, then it will not be pumping as much air at the middling engine revs, giving a marginally lazier transient response but eliminating surge - and also giving excellent high end power. I actually think it was a clever and practical way of making the turbo mate well - just not how I would have/did do it.
If you are insistent on doing a Garrett GT2871R cartridge type high flow into RB20, depending on your exact objective then go either 48 or 52T comp, and use the RB20/25 turbine housing. If you can get some piping mods sorted, use the Garrett 0.60 A/R comp housing and have something close to a GT-RS. Just remember the more fabricating you have to do, then the financial advantages of going with this decision start to diminish.
cheers
Edited by Dale FZ1
Not really on topic but dale fz1 you sound like you know a fair bit about turbos, can you recommend any good reading, books articles etc for learning about flow maps, how to match compressors to a/rs to motors etc?
i agree dale, the 56t matched to the rb20/25 housing is definately on the edge. would be even worse on the stock bottom end, i actually order the 52t 2871r in the first place but the workshop i purchased it from sold me a 56t telling me it was the 52t, when i questioned him about it he said he hadnt realised and offered to chase up the proper comp but called me back 2 days later saying it would take him 2-3 weeks to get the wheel in. was sick of his BS by then so i ended up just keeping the 56t.
the turbo works really well, just make sure you have the wastegate bored out as much as possible if using any of the nissan housings.
Not really on topic but can you recommend any good reading, books articles etc for learning about flow maps, how to match compressors to a/rs to motors etc?
We'll stick on-topic here, but try
www.turbobygarrett.com and read their tutorials; they are very, very good and easy to follow
Turbochargers by Hugh MacInnes (if you can find a copy, will be in specialist bookshops).
I have another text that was published early 90s and still on loan to my mate.
cheers
its internal gated
have always had boost issues, previously, boost always dropped off, now spikes. Changed controllers no diff.
Its all good though, car doesnt ping and knock levels do not go over 20
h.
That you have knock apparently well controlled is a good thing.
I wouldn't be at all happy with the boost skyrocketing at the top end of the rpm range - recipe for a hand grenade under the right (read: wrong) conditions.
So your 2871R is fitted to an SR20, uses a .63 A/R turbine housing? It's a stock, off-the-shelf Garrett unit fitted to a fairly stock engine and manifolds?
What was changed that you went from boost falling away to boost running away?
Main point of interest is if there are any lessons to learn in fitting a similar spec unit to an RB20.
cheers
Hi boost at top end is not an issue, as i dont take it past 7000rpm. As you can see from the dyno. Hi boost is an issue down low, as thats when rods can break. Up top you'l only damage rings (so i have been told).
There 2 things that we are assuming which is the problem to why boost sky rockets
1. I have re-ground exh cam with ajd cam gear - that may need adjusting. Have set it to 0 and just fitted cam. If i play with the timing it may stop the boost spike and give me a fatter mid range.
2. Wastegate hole needs to be machined
I wont be doing anything for now as im happy.
cheers
i agree with Dale in that the ideal combo for a RB20DET would be a 48T GT2871R with a RB25 exhaust housing. this would allow the turbo to easily mate with the standard manifold and dump pipe if required.
the 56T comp wheel is just too big for the 76T turbine where it is able to flow enough air for ~475hp, whereas the 76T's efficient limit seems to be ~400hp. Also, i believe the 52T is probably as big as you'd like to go on the GT2871R although be it with an A/R .86 exhuast housing for ease of flow and increased efficiency.
if you look at the garrett website (www.turbobygarrett.com), you will see that the efficiency of the 76T turbine actually decreases as you go bigger in compressor wheel.
anyway, just my 2c, feel free to put me in my place if you feel you need to :)
  • 1 month later...
I have just purchased a HKS GT2530 upgrade kit from nengun Japan for my R32-RB20DET as my stock turbo shredded all the turbine blades like potato chips last week. I have been doing tons of research into which is the best and most practical turbo upgrade for the RB20 with T3 flange and I have decided to go with the 2530.
I have a long way to go and alot of mods to complete the project. I will keep you updated on how the installation goes and on final dyno results.
There are so many paths to take when upgrading the RB20 turbo. I hope my experience will help some of you to make the choice that is right for you.
Rgds, Grippy :P
Rgds, Grippy :laugh:
Yeah well I'm in the same boat too but I ordered the HKS GTRS. It should be here sometime this week from nengun. Could be a few weeks yet till I can install it but it should be a well worth the wait.
    • Oof. One of my mates has an R34 GT-R that he initially was a "I want to go twins for response and convenience" on his stock 2.6 with Kelford 272 cams, but his friends are pests and were always in his ear about their place being in the bin.   Eventually one of the 2860-5s decided to add it's own input and force his hand, so he conceded and went for a Pulsar 6262G ("G35 900") with T4 0.85 hotside.    Here's an overlay of the results, same cams, same stock bottom end, same boost, same fuel, just from a pretty tidy 2860-5 install to a Pulsar turbo on a 6boost maniifold on BP98.   Worth mentioning here, it may seem like a dead horse thing but the dyno plot doesn't tell the story of how much better it is to drive - transient response has completely changed the car, he used to have flat foot shifting to stop it having to wind up again on gear changes even at >7000rpm... now it builds boost faster than that even short shifting.   It's 100% transformed the car before you even consider how much better it holds on: Pulsar and Garrett aren't the same, but from our experience if you're just looking for a better drive and the ability to make the same or more power I think the divided G30 770 would probably be the smallest I'd go to.
    • Great work Duncan, any events local you will give it a test once all done?
    • Sweet, yeah hoping stock gears will hold up. May use the transbrake feature on hill climb starts so that will test it.
    • Yeah, the thread is only nearly 20 years old.
    • Been down in Tassie for 2 weeks (a cruise, not a race for once) but spent a little time on her when I got back. I worked out the injector settings in the PowerFC were not correct for nismo 555s, set those to 66% +10ms and added a little air at closed throttle, set the timing (approximately, because it has some weird non 15o cells around idle) and now she starts and idles properly. She purrs like a kitten (ignore the co2 alarm in the background, I did  ) 20250518_171052.mp4 Next step, off for run-in, tuning and alignment!
