Can anyone link me to where to download newer data? I only have the 2001 dataset, and would like some more modern data. Just need A1, A2, A3, B1 and B2.
But for now, can somone please FAST
PV35400829 for me? Any chance of Sewid or someone else who speaks Japanese translate the options for me? Also, is anyone will to translate an auction sheet for me?
Cheers
Feb '93 GT-R, colour code 326 ('Crystal White'), Interior colour 'G', there are pages of data on how to interpret the last few digits of the Model Code, but I got a bit lost!
(KBNR32RXFFS7AA)
But nothing fancy to report.
Hi all,
Could someone be so kind to FAST a VIN for me?
BNR32307816
Supposedly a '94 In GMG.
Cheers
Grant
Yeah it comes up in fast that way.
Model: KBNR32RXFS7AA
Build Date: 03/1994
Color: KH2 (Gun Metal)
Interior Color: G
Nothing else special to report.
Cheers
Send Chook a pm he will be able to help you out as he has the newer version of fast.
Can someone fast BNR32-301013 for me plz?
can some one do mine please
BNR32-303985
cheers
Hi, can someone please help me check up the VIN for this car?
BCNR33002497
Model number GGJPRQFR33ZDAG
Thank you!
Your vin doesnt come up. You might have gotten the numbers wrong but tried the model code too and all it said was invalid model. Might want to recheck your number etc
Thank you very much. does it tell you the engine number that the car came with at all?
just out of curiousity? just want to see if that matches up with original engine.
No fast doesnt give the engine number. sorry mate
Adam,
Thank you.
Yes it's just a GMG BNR32, nothing to see :P
Cheers
Grant
hahaha, R32's are my fav model I was just saying no special features that I could see. I would kill for a late model Gun Metal 32GTR (even better if it was V-Spec II). I have a 32 GTS-T hence the pic but I am a little pissed because it had a respray before I owned it and it was gun metal but I do like the blue just wish I could work out what blue it was.
Hi Baby skyline, thank you for your help. I guess the seller must have given me the wrong VIN number. Decided not to get the car in the end and got a R32 GTR instead. =)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
