Diff =/= Final Drive.
Final drive ratios for All 32 GTST's manual or auto are the same as R33 Auto Ratio (4.3:1) Manual 33 GTST's run a 4:1:1 final drive ratio.
The differential bolts inside of the crownwheel(Parts of the final drive) and this gives you your LSD. When you buy a Nismo LSD kit you will not get a new final drive crown and pinion so your ratio will stay the same.
Well there ya go, cheers mate :thumbsup:
Hello!
Would greatly appreciate some help. I think this is the correct VIN. (hopefully)
The car is imported from Britain to Sweden. I don't know if that information is needed.
#WGNC34018235
Cheers guys!
Edited by Miltuun
Thanks for that! does this program do anything else? or just provide those details?
Can provide part numbers and Model Options. Miguelone can translate better than I can.
WGNC34129431 Please. Thank you very much in advance!
Wow! It's a regular Stag Fest lately. :D
Edited by Not a Pulsar
Hah yeah I saw another Stagea member post it in the stag section and he got directed to here so I thought, why not !
I had trouble with fast before as I run win764bit. Now have just found fast 2010 64bit compatible here - http://club-s12.org/retro4/index.php?topic=32213.0
download will be finished in 4 mins
Thanks for the quick response!
Nice one. Ima needing a more recent 32bit version. :(
I am not sure if I misunderstand you. Are you saying that it won't work for you ? It's 32 and 64bit compatible incase you thought it was only 64bit.
Sorry if I misunderstood. It's the sad smiley that has me all confused :D
More recent US version using older Jap files will be the same as using the older version though. Have a look around for the 2009 Jap version for the catalogues and use the current english version program. Works the best.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
