Diff =/= Final Drive.
Final drive ratios for All 32 GTST's manual or auto are the same as R33 Auto Ratio (4.3:1) Manual 33 GTST's run a 4:1:1 final drive ratio.
The differential bolts inside of the crownwheel(Parts of the final drive) and this gives you your LSD. When you buy a Nismo LSD kit you will not get a new final drive crown and pinion so your ratio will stay the same.
Well there ya go, cheers mate :thumbsup:
Hello!
Would greatly appreciate some help. I think this is the correct VIN. (hopefully)
The car is imported from Britain to Sweden. I don't know if that information is needed.
#WGNC34018235
Cheers guys!
Edited by Miltuun
Thanks for that! does this program do anything else? or just provide those details?
Can provide part numbers and Model Options. Miguelone can translate better than I can.
WGNC34129431 Please. Thank you very much in advance!
Wow! It's a regular Stag Fest lately. :D
Edited by Not a Pulsar
Hah yeah I saw another Stagea member post it in the stag section and he got directed to here so I thought, why not !
I had trouble with fast before as I run win764bit. Now have just found fast 2010 64bit compatible here - http://club-s12.org/retro4/index.php?topic=32213.0
download will be finished in 4 mins
Thanks for the quick response!
Nice one. Ima needing a more recent 32bit version. :(
I am not sure if I misunderstand you. Are you saying that it won't work for you ? It's 32 and 64bit compatible incase you thought it was only 64bit.
Sorry if I misunderstood. It's the sad smiley that has me all confused :D
More recent US version using older Jap files will be the same as using the older version though. Have a look around for the 2009 Jap version for the catalogues and use the current english version program. Works the best.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
