Could you please look up Z33422728
Thanks very much
My FAST won't. :(
Can someone run this please
6u9000bnr34006706
Its meant to be a V-spec 2
April 2000, QM1 - Cloud White, V-spec
Seems to be V-spec 1.
My FAST won't. :(
{style_image_url}/attachicon.gif BNR34 006706.JPG
Thanks bud my mate will be pissed he just got it delivered a few days ago and was sold to him as v-spec 2 it must of just had the 2 add ons
It has quite a lot of add on's.
I ran the VIN and found it has:
Super Fine Hard Coating
Advanced Aero System
Glove Box Lamp
UV Cut Insulated Glass
Privacy Glass
Remote Control Entry
Rear Fog Lamps
Multi-Display Meter
Trunk Lid Trim
Rear Wiper
BNR32309671 Please
Frame/Series BNR32/R32 Body 2K (2-door sports coupe ) Engine RB26DETT (2600 gasoline twincam twin turbo ) Drive HI.4WD (4 wheel drive with HICAS ) Production month 05.1994 Grade GT-R Transmission MT.F5 (manual transmission floor 5-speed ) Interior color G Body color 326
Edited by ecliptor
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
