Cold region package is heated mirrors etc.
Hi (00)Skyline(00),
I think Miguelone is correct with the mirrors.
The car has heated seats too. I'll try to upload some pics but I'm a bit of a noob in that regard.
I see, it would defiantly come in handy for the winter.
Sounds good :)
Ok, so i have done a revs check on this car and its showing it was complied in 05/1990 and that its a vspec?
V spec were made 93?
Anyone know whats the deal here?
Yes, V-Spec's were made in 1993.
Post the Model Number and let me have a look.
It's the number starting with "KBNR32..." Under the Chassis Number on the blue plate.
BNR32-008320
KBNR32RXFSLTAA
Im not sure why its showing the compliance date as the build date also, through the revs check?
REVS is wrong.
Compliance Date can not equal the build date... That's impossible as it was built in 05 - 1990 and only just came to AUS.
Compliance Date usually refers to when the car was complied to AUS Standards / ADR Laws.
Your model number checks out to be a Base Model R32 GTR, made in 05 - May.
KBNR32RXFSLTAA - "X" signifies it is a GTR (16 Inch Wheels) = Base Model.
If the "X" was a "B" then it would = V-Spec (17 Inch Wheels)
On a side note: KBNR32RXFSLTAA, "L" = Fog Lights from factory... You have fog lights on the car?
Is this genuine V-Spec?
Vin-BNR32-302657 (Chassis No)
Model-KBNR32RBFS AA
These numbers are on the Blue Compliance plate from Japan I believe.
Thanks in advance.
Edited by glaze
BNR32-008320
KBNR32RXFSLTAA
Someone messed up when they did the registration. See it on imports a lot. Either build date is compliance date or compliance date is build date lol.
Model-KBNR32RBFS AA
Thanks in advance.
Anypne help me out with this? I have done some more research and I am 99% sure it is a VSpec, but just want it confirmed:) Thx
Model-KBNR32RBFS AA
Thanks in advance.
Vin- 6U9000BNR32302657
Eng-RB26 078615A
Yeah, the VIN and Model Number it checks out to be a V-Spec:
Sweet! Thx (00)SKYLINE(00). Put a deposit on this tonight and will have in my hands next weekend.
Sounds good, post some pics :)
Visibly you should be able to tell in stock form:
Brembo Front and Rear Calipers.
17 x 7 +20 or 17 x 8 +30 BBS Wheels (Check the centre of the wheels)
V-Spec Sticker on the boot lid.
A retuned ATTESA E-TS system but that you wouldn't be able to tell straight up.
It doesn't come with Rear Brembo's unfortunately or stock wheels. Will start the search for these ASAP;)
Interesting... So it's got stock Brembos on the front but not on the rears...
So what's on the rears? Just "Nissan" (Sumitomo) calipers?
  • 3 weeks later...
Can someone please check
BNR34-001021
Thanks in advance!
Is it possible to get late KV36 model checked which doesnt come up in FAST system. KV36-400752
Thanks in advance
I am getting mix of 5 results but all the listings say the build date is December 2008...
Thanks Mate,
Does it show what factory options it has and all like the FAST system or just the build date? Build date of Dec 2008 sounds right.
Edited by rawzz_v35
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
