You quoted another members (ER34sedan) VIN in which I did a search for.
That one's not for you.
That's my one.. 1993
Here is yours.
If it were a V-Spec, the Grade should state GT-R 17" Wheel.
Do you have factory Brembo Calipers on your GTR?
Your Model Number = KBNR32RXFS7 AA
The Grade of your Skyline is X = GTR 16" Wheels
The GTR Grade = 7 = GTR
The GTR Grade Continued is = AA = GTR & V-Spec / V-Spec II.
AA will be there regardless if it's a Base Model or V-Spec or V-Spec II.
So meaning, if you have a Base Model, it will state AA.
If you have a V-Spec and or V-Spec II, it will still state AA.
Would you mind checking my 32
BNR32-001148
Also would it be possible to check my STI?
GDB-037648
Thanks
Josh
Can you please check whether my Stag is an Autech? After browsing forums on this topic I'm starting to think it might not be.
6U900WGNC34103968
I'll be forever in your debt.
Cheers.
Zane.
Grade = 260RS = RB26DETT (Autech)
I always thought all 260RS were all Autech's..?
Yeah that's right I just wanted to make sure mine is a 260RS and not just a RS4 with a RB26 transplant.
Thanks mate my mind is at ease. :)
Yeah all good :)
You got the front and rear Brembo Calipers too?
You don't see a Deep Marine Blue coloured R33 GTR V-Spec all that often.
ty so much shes left hand drive 41k kms with an
hks step 2 2.8 kit
n1 block
hks 272 11mm lift
gredy intake
titanium midori exhaust
twin gt2871rs on n1 manifolds
greddy fmic
r34 getrag 6speed
hks twin plate
ohlins 2way suspension
hks pro suction kit
reinix oil pump
haltech pro plug in
trust oil pan with baffles
auto select front carbon lip and canards
nismo roll cage nismo
lm carbon rear wing
and a real nice defi gauge display
on volk te37s 18x10 +12 offset shes a looker and a killer
hks step 2 2.8 kit
n1 block
hks 272 11mm lift
gredy intake
greddy fmic
r34 getrag 6speed
hks twin plate
hks pro suction kit
reinix oil pump
haltech pro plug in
lm carbon rear wing
Nice!
Who built and tuned it?
What's the power out put?
:blink: Left hand drive?!
Nice!
HKS built it i freshened it up with a some new acl bearings and a new set of hks step 2 ti piston rings cost me 400 used the set, as for the tuning i live in peru soo me and my mate tune it we get by on our own my last rb26 dyno'd 830rwhp at 2.5bar out of a billet 67 mm borgwarner turbo with pump gas and meth injection, goin for 750awhp also have a brand new t04z kit i might put on if i dont like the twin setup here are some pictures of the car in the shop and its first time out still gota paint the bumper on it but man is she a looker
Edited by Regan2860
Wow! That's interesting and left hand drive looks so funny... Cause I am so use to seeing right hand drive Skylines :laugh:
Good on you for doing it on your own with your friend.
HKS always do a good job.
Looks like it's making some decent power.
I prefer the twin setup myself but see how you go.
Thanks!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
