Firstly oil temp. I am rewiring a bunch of meters, and i always thought you wanted to measure the temp of oil in the sump. So in my case i would place the temp sensor after the oil cooler, so i get an idea of the temp of oil the engine is about to ingest.
Now a friend was sayign recently that his mechanic had it on the oil line to the cooler so you read the temp of the oil coming out of the engine.
So anyones thoughts on who is right or why they plumb theirs a certain way.
Also with the oil pressure sensor, does anyone know the thread size? I was going to plun my new VDO sensor in the location of the std sensor. Can you just run a t-piece in the oil cooler lines??? Doenst seem ideal but would make life easier during the insall
you measure water temp after it leaves the engine ....
i would think the same applies to oil temps
but then again, nearly everyone says sump to me aswell. other than people who have the sandwich plates and they just use them without knowing whether its in or out feed
Not sure with piston engines but I know with turbine engines the sensor is generally on the scavenge side of the system, so between engine out and the cooler, it's said this indicates failure more quickly. Makes sense to me that it would work the same way with cars.....
Measuring from a t-piece isn't the best solution as this creates a restriction in the flow, better if you can use an inline sensor.....
Well i will probably end up just teeing into the std location and running some 1/8" tube or something to the inner guard where i will mount it.
The vibration is meant to hurt then if you mount them direct to the engine hence my wanting to use a tpiece into the cooler line...also helps with access
i just mounted the sensors for my defi gauges (oil pres, oil temp) both into the side of the greddy remote filter mount.
on the afla we run a line (braided) from the standard location up to a little 'bar' which is milled from a billet. it has a hole in each end (one is blocked, one has the feed) then 3 holes in the top. One has pressure sensor, one temp, one warning buzzer sensor. It is basically a little fuel rail. very neat way to do it, and it means we can mount it on the firewall so the wiring is away from all the hot stuff. and it's all easy to access.
wouldn't the temp one lag with this not being a flow through type setup ??
once the line is primed wouldnt the oil that is there to start with not be removed from its place if its pressurised ?? hence taking a long time to heat up since it isnt passing through the engine.
just thinking of the path of least resistance..
  • 3 weeks later...
in addition to the above, can anyone help me out regarding the method of changing the oil pressure sender on an R33?
I have the new sender and can see where the plug goes into the old one, just need to know how to go about changing it or whether it is best left to a mechanic. don't want oil to be spilling out all over the place if i remove it.
this is a requirement of a RWC and i kinda need this sorted this afternoon!
any help hugely appreciated.
(apologies for posting in 2 sections, need an answer asap)
nah, the oil is definately flowing through there. oil temp is responsive enough, oil pressure is really responsive too. it's amazing how much faster it works than the stock gauge, though at a constant reading their values are very close.
tommo, are you sure oil pressure guage is a RWC requirement? most cars dont even have one.
sorry, it's not the actual guage, he sighted "oil around oil pressure switch (sender)", possibly from me spilling a little oil when changing the filter last. only item on his list other than stock airbox ;)
thought fair enough, rang up bursons and got the part, but now the mechanic is too busy to fit it this arvo.
buyer is flying in tonight and driving back to the ACT, so i'm kinda in a bit of a hurry
Edited by thommo
I'm about to do what Beer Baron did, was going to tap it into the sump but the guys at Motorsport Connections said that a t to a remote location on the chasis is fine and very common
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
