Firstly oil temp. I am rewiring a bunch of meters, and i always thought you wanted to measure the temp of oil in the sump. So in my case i would place the temp sensor after the oil cooler, so i get an idea of the temp of oil the engine is about to ingest.
Now a friend was sayign recently that his mechanic had it on the oil line to the cooler so you read the temp of the oil coming out of the engine.
So anyones thoughts on who is right or why they plumb theirs a certain way.
Also with the oil pressure sensor, does anyone know the thread size? I was going to plun my new VDO sensor in the location of the std sensor. Can you just run a t-piece in the oil cooler lines??? Doenst seem ideal but would make life easier during the insall
you measure water temp after it leaves the engine ....
i would think the same applies to oil temps
but then again, nearly everyone says sump to me aswell. other than people who have the sandwich plates and they just use them without knowing whether its in or out feed
Not sure with piston engines but I know with turbine engines the sensor is generally on the scavenge side of the system, so between engine out and the cooler, it's said this indicates failure more quickly. Makes sense to me that it would work the same way with cars.....
Measuring from a t-piece isn't the best solution as this creates a restriction in the flow, better if you can use an inline sensor.....
Well i will probably end up just teeing into the std location and running some 1/8" tube or something to the inner guard where i will mount it.
The vibration is meant to hurt then if you mount them direct to the engine hence my wanting to use a tpiece into the cooler line...also helps with access
i just mounted the sensors for my defi gauges (oil pres, oil temp) both into the side of the greddy remote filter mount.
on the afla we run a line (braided) from the standard location up to a little 'bar' which is milled from a billet. it has a hole in each end (one is blocked, one has the feed) then 3 holes in the top. One has pressure sensor, one temp, one warning buzzer sensor. It is basically a little fuel rail. very neat way to do it, and it means we can mount it on the firewall so the wiring is away from all the hot stuff. and it's all easy to access.
wouldn't the temp one lag with this not being a flow through type setup ??
once the line is primed wouldnt the oil that is there to start with not be removed from its place if its pressurised ?? hence taking a long time to heat up since it isnt passing through the engine.
just thinking of the path of least resistance..
  • 3 weeks later...
in addition to the above, can anyone help me out regarding the method of changing the oil pressure sender on an R33?
I have the new sender and can see where the plug goes into the old one, just need to know how to go about changing it or whether it is best left to a mechanic. don't want oil to be spilling out all over the place if i remove it.
this is a requirement of a RWC and i kinda need this sorted this afternoon!
any help hugely appreciated.
(apologies for posting in 2 sections, need an answer asap)
nah, the oil is definately flowing through there. oil temp is responsive enough, oil pressure is really responsive too. it's amazing how much faster it works than the stock gauge, though at a constant reading their values are very close.
tommo, are you sure oil pressure guage is a RWC requirement? most cars dont even have one.
sorry, it's not the actual guage, he sighted "oil around oil pressure switch (sender)", possibly from me spilling a little oil when changing the filter last. only item on his list other than stock airbox ;)
thought fair enough, rang up bursons and got the part, but now the mechanic is too busy to fit it this arvo.
buyer is flying in tonight and driving back to the ACT, so i'm kinda in a bit of a hurry
Edited by thommo
I'm about to do what Beer Baron did, was going to tap it into the sump but the guys at Motorsport Connections said that a t to a remote location on the chasis is fine and very common
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
