Firstly oil temp. I am rewiring a bunch of meters, and i always thought you wanted to measure the temp of oil in the sump. So in my case i would place the temp sensor after the oil cooler, so i get an idea of the temp of oil the engine is about to ingest.
Now a friend was sayign recently that his mechanic had it on the oil line to the cooler so you read the temp of the oil coming out of the engine.
So anyones thoughts on who is right or why they plumb theirs a certain way.
Also with the oil pressure sensor, does anyone know the thread size? I was going to plun my new VDO sensor in the location of the std sensor. Can you just run a t-piece in the oil cooler lines??? Doenst seem ideal but would make life easier during the insall
you measure water temp after it leaves the engine ....
i would think the same applies to oil temps
but then again, nearly everyone says sump to me aswell. other than people who have the sandwich plates and they just use them without knowing whether its in or out feed
Not sure with piston engines but I know with turbine engines the sensor is generally on the scavenge side of the system, so between engine out and the cooler, it's said this indicates failure more quickly. Makes sense to me that it would work the same way with cars.....
Measuring from a t-piece isn't the best solution as this creates a restriction in the flow, better if you can use an inline sensor.....
Well i will probably end up just teeing into the std location and running some 1/8" tube or something to the inner guard where i will mount it.
The vibration is meant to hurt then if you mount them direct to the engine hence my wanting to use a tpiece into the cooler line...also helps with access
i just mounted the sensors for my defi gauges (oil pres, oil temp) both into the side of the greddy remote filter mount.
on the afla we run a line (braided) from the standard location up to a little 'bar' which is milled from a billet. it has a hole in each end (one is blocked, one has the feed) then 3 holes in the top. One has pressure sensor, one temp, one warning buzzer sensor. It is basically a little fuel rail. very neat way to do it, and it means we can mount it on the firewall so the wiring is away from all the hot stuff. and it's all easy to access.
wouldn't the temp one lag with this not being a flow through type setup ??
once the line is primed wouldnt the oil that is there to start with not be removed from its place if its pressurised ?? hence taking a long time to heat up since it isnt passing through the engine.
just thinking of the path of least resistance..
  • 3 weeks later...
in addition to the above, can anyone help me out regarding the method of changing the oil pressure sender on an R33?
I have the new sender and can see where the plug goes into the old one, just need to know how to go about changing it or whether it is best left to a mechanic. don't want oil to be spilling out all over the place if i remove it.
this is a requirement of a RWC and i kinda need this sorted this afternoon!
any help hugely appreciated.
(apologies for posting in 2 sections, need an answer asap)
nah, the oil is definately flowing through there. oil temp is responsive enough, oil pressure is really responsive too. it's amazing how much faster it works than the stock gauge, though at a constant reading their values are very close.
tommo, are you sure oil pressure guage is a RWC requirement? most cars dont even have one.
sorry, it's not the actual guage, he sighted "oil around oil pressure switch (sender)", possibly from me spilling a little oil when changing the filter last. only item on his list other than stock airbox ;)
thought fair enough, rang up bursons and got the part, but now the mechanic is too busy to fit it this arvo.
buyer is flying in tonight and driving back to the ACT, so i'm kinda in a bit of a hurry
Edited by thommo
I'm about to do what Beer Baron did, was going to tap it into the sump but the guys at Motorsport Connections said that a t to a remote location on the chasis is fine and very common
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
