  • 1 month later...
Does anyone have stock R33 GTS-T rims with legal tread? After the exhaust defect from the other night, i'm going to get my intake/intercooler engineered and exhaust, but I don't think they will let me through with my rims as the tyres are only 88 load rating (Mick, why did federal have to go so low on the 265/35s :D:cool: )...
or if not for anyone having stock 33 rims, does anyone have rims that will fit and have legal tread that don't require spacers?
None of this will be needed until next week sometime i think considering how hard it will be to book a rego inspection in the first place..
  • 4 weeks later...
  • 1 month later...
  • 4 weeks later...
hey all i got my skyline r33 gtst not to long ago but need some parts to get it over the pits
dose any one have
stock spring
stock wheels with good rubber
that i can borrow or rent for a couple of days
Hi ka-os1,
I've got a set of stock rims with about 95% tread on them. One of the rims looks like it has been in a slight fire though as it has yellowy discolouration on one corner. I don't know if they would knock it back on that or not. I've been planning to paint the black to cover it up, but i've been overseas with no time on my hands.
Your welcome to come borrow them for the pits, let us know. I don't visit this thread often so PM me.
Cheers
Sam
  • 1 month later...
  • 3 weeks later...
hey guys,
got a rego check on friday for a R32 gtst. was jsut wondering if anyone has some stock parts they are willing to lend, or sell, so i can hopefully pass.
stock R32 rims with good rubber.
stock gearknob.
stock airbox.
and my reverse lights dont work...any ideas??
i can't think of anything else that they wouldn't pass me on, but im sure theres some others so if theres anything else some one failed on...let me no??
prefer southside...and by friday.
thanks
gus
just take it as it is first.
If it gets knocked back it's ok. you expect it.
if it passes its a nice surprise.
If you have something obvious to get knocked back on they wont be looking for stuff to fail you on.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
