  • Replies 81
Not interested in changing the turbo atm, just looking to make what i have work.
I was hoping for over 300 but if its not going to get there then im thinking i may as well go back to standard.
log style manifolds are crud
try and find a hks cast low mount manifold. They look stock enough
But then all the intake and dump needs to be made again as it dosnt put the turbo in the factory location.
But lets just get back to the requirements at hand for a second…
1. Tight budget – so clearly no $1400 manifold manifold, custom piping, new dump etc
2. As factory as possible appearance
3. No more than 300rwkw
As to wether it’s the best performing setup, giving the best performance etc etc - really is not the question or issue here at all.
So who cares of its “crud”. It’s been proven to work & the stock manifold fits those requirements perfectly.
Lithium is making 300rwkw on a stock manifold with a 3076 .82 internally gated on a 200,000km motor.
Seems to work for him, and drives as smoothly as my 77,000km motor.
He had one of those exact manifolds on his for a while. I think he got it for quite cheap so tried it. Made the car sound pretty awesome, but blew the welds at the flange after a while so went back to the stock.
I think it had something to do with this:
lol
How much of a difference was there, both on paper and seat of the pants?
Seat of the pants, basically none - which actually surprised me. The most power I have made on paper was with the stock cast manifold I put back on after the stainless one failed. It SOUNDED like something more serious with the stainless manifold though, which gave an unjustified sensation of speed.
Lol all this talk about 3071/76/35r....
he wants a high flow or a 2530?
Stock manifold is fine...+ heat shields + factory EVERYTHING = you get to smile when you get asked to pop your bonnet..
ummmmmmm 2530??? where did you get that from, i have a 3540!
It pays to read the whole thread, the first post was 5 years ago, i chose to bring it up again as it has relevant information and was interested to see if there has been any definitive answers gained in the 5 yrs since this was posted, its also relevant in that its the exact same manifolds being talked about today as it was 5 yrs ago when the thread was posted!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
