Im 4wd... would they drop my front transfer shaft?
meh. pity, Id like to have a funrun but Im not going to pull the shaft myself; guess Im stuck with the 4wd dyno boys.
sounds like fun tho.
  • Replies 422
Posted Images
damn broken suspension.... i would love to have come and bring some old flava to the mix but im out of action... sorry guys, might come down and watch but
yeah ill be in and i imagine Lee will be in also
most of us are 4wd it take roungly 5 mins to take out the front shaft out u will also have to take out the 4wd fuse
from memory he wouldnt take shaft out as there is to many of us and would become a hasel
im sure sum1 could help you if your not confident to do it yourself
A warm up run then a run in in shoot out mode.
I wont be running my car, dont have a Nissan anymore, do I know you DCGTST?
ummmm.....not that i know of. Ive been on a few cruises, and know a few people from boostworx
Depending on numbers I guess, would you be open to having a 'shared day' with some calais turbo people? We were thinking of having one around then as well at boostworx. These aren't your typical boongers ripping skidz down hindley street haha.
http://calaisturbo.com.au/showthread.php?t=83052
Can i add at a dyno day Shaun had a small while ago for another car club (not mentioning names *cough* silvia *cough*) some knob decided to do a burnout in front of his workshop to celebrate his power figure....
One of the nearby residents called the police, and they came and shut down the dyno day.
If anyone does any similar behaviour be prepared to have all other members of sau sa looking down at you....
I'll be in....to watch :)
I don't think the dickhead was celebrating, more like having a sook as it read 50rwkw less than the dyno happy dyno he tuned it on the night before:)
Apparently it has blown up now..what a pity
cheers
darren
Darren,
What dyno did he run on the night before to read 50rwkw more????
From what ive seen, Shauns dyno seems to be fairly accurate.
I personally wouldn't mind a few calais turbo ppls, always widens some of the skyline ppls eyes with how much potential the old RB30ET has and power made with simple mods... :)
If these guys (VL's) are going then I either want to be the very first or very last when no-one is watching lol. Seeming they put out an average (when modded) of anywhere between 200-500 rwkw (i know they can do more if made to do so :)). This is if i'm able to make it due to footy finals -> Be same weekend. So I'm 50/50 to be in. I can pay the deposit if need be, but can't guarantee I'll be there :s
I should get some tyre spikes and wait down the street incase anyone decide to leave marks!
Edited by DC_GTST
nah I reckon having too wide variety of cars ruins it .... would be far better if we just restricted it to Skylines with the odd Silvia thrown in. Just my 2c.
Will, I have Paypal'd you the $10.
I don't mind a few VL's rocking up as they did last time. After all they are an RB 6cyl Turbo. :)
The only thing I would suggest is maybe no NA VL's or even NA silvia's etc.
Its even good having the odd LS1 on there, spices up the day and gets people interested again. Have the same lightly modded 32/33/silvia after 32/33/silvia and it tends to get a little boaring.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
