i got it from carmate.
they dont come cheap though, lol
Hey mate, can you please tell me if these hods fit good?
Also, can you please send me a link from carmate's website to the same one you got?
Thanks.
Thanks.
I'll be buying one from PSI parts soon... Definitely need a vented bonnet, things are getting very warm.
Well car is now back on the road - in it's run-in tune
Here are some updates of the engine bay and run-in tune.
Engine bay looks tidy. Great power figures for a run in tune. Let us know what it makes when its run in.
just got my coilovers installed by Anth & Alex @ Dahtone Racing :P
BEFORE:
AFTER:
( sorry bout the dodgy camera phone pix :P )
exhaust sits 3.5cm off the ground (1/3 of a V can - in this case its a PimpJuice can :lol: ). I will raise the rear end when i take the car out again lol
but that aside..... it looks hot :)
edit**
just came back from a nice drive, coilovers feel awesome!
going to raise the rear end tomorrow though :(
heres some last pics before it gets raised :)
so happy with them :D got a smile from ear to ear :D
Edited by McDrifto
McDrifto - love it!
seriously i'd just leave it like that and not ruin it with any bullshit kits or rims
:D
sif leave the stockies on for looks. get some deepdish 16' or 17' if u wanna leave the car at that height. agree bout the kit tho
fark man your rear camber tyre were that low will be awesome... :thumbsup:
heres my nugget yesterday.
got my standard 33 rims back on as they have my semi's (r32 gtst rims painted black for normal driving)
ive decided to save up for some new rims so it sits higher and also i want a CF hood - no crazy body kits here :)
i adjusted the coilovers to the highest possible safe point (left 2cm of tread in the purches/cups) and measured all 4 so they were even lol
the coils themselves are all the way up and cant go any higher... that means it wasnt on the lowest setting yesterday LOL
heres a pic of the car at its highest setting
what coilovers are they? are they bottoming out at that height?
HSD coilovers with soft spring rate. They dont bottom out and it wasnt on the lowest setting in the previous pics, the ride is smooth!!!
In the previous pics the bottom purches/cups were wound all the way down, the coils themselves were all the way up. The coilovers could of been wound down a lot, which if it was you wouldnt be worrying about bottoming out because your car would be dragging on the floor
Edited by McDrifto
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
