I forgot turn of my front light when i leave the car today, The Battery was run out. After RACQ's help, engine start again, but my torbo timer was not working anymore, even cannot turn it on.
Anyone know what's happend? and how to fix it up? THX!
it is a Greddy Torbo Timer on R33.
thanks guys! new carbon bonnet to come... mechanic desided to go for a drive without putting the bonnet pins back in so its cracked right through the middle now... can't really tell from the pics but its fubar!
lucky it didn't hit the windscreen or roof... that would have been upsetting
Just spent 2 hours cleaning my N/A
just fitted full top secret kit and stealth wing
it has sparco viper rims (wide!) hard to keep clean zzzz btw if anyone has a center cap that i lost ill buy it off ya..
just a catback exhaust and some goodies inside the car..
give it a year once i get off my P's going to turbo it.. so yeh next on the list is brakes and diff. :P
heres a couple of pics.. tell us what ya think :)
cheers
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
