And no offense, but those clear tail lights on the silver one look horrible.
Have to disagree.
To be honest, i never liked any aftermarket tail lights on Skylines and have seen those lights on other 33's but not on silver 33's. I like it, on the silver, and think it's suits the car well. Unfortunately, it's a defect waiting to happen, due to the absence of a red reflector :(.
Nice clean looking car W3APON.:)
Love yours too Brandon, especially when it sat lower :)
Simple and clean
Thanks buddy. When the power craze strikes again, I'll be having a full custom exhaust and hopefully that'll fix the issue (I'd expect it to be 10mm difference). Also thicker tyres would add another 10mm too (currently on 285/30/18) by swapping 285/30 to 265/40.
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
