There are some really nice R33s in here :)
I really like the glowing red boot garnish on JDMs.
Pitty mine is so ugly.
The interior is missing a few items as you can see... but I think all the fun parts under the bonnet more than make up for it :D
  • 3 weeks later...
I've been lazy about posting anything recently, Roll cage, fuel cell are coming. Trying to find someone who can help install a 'Stack' gauge. I'm colorblind so I always put the wrong wires together.
Night fury :)
The interior has changed a fair bit since....what with the green neon strips and blue led gauges..but yeah....my daily ride and pride and joy...oh n she isnt exactly 'slow' with 216 rwk @ 11psi...im in love...lol
Edited by jez NF
Just Jap. Took a lil bit of trimming and adding to fit. Otherwise it aint too bad. Just replaces the factory lip. Gives it more of a sporty look to the front without looking over the top whilst keeping the strength and fit of the factory frontbar.
Luke
hey man...i love it too
How much did you buy it for??? painting cost?? trimming?? (easily done?) pm me plz if u can
cheers
