thanks mate. will be doing the E85 trick early next year, thinking 370rw wasps or so with a slighty beefier midrange should keep me busy for a while.
bonnet is Mu Secret. but that z tune style only comes on the S1 bonnet, S2 is different. good bonnet tho, I'm happy with it.
Took first place in the Special Interest Category at the 2011 Stand Up Tohoku Car Show! Pictured here next to a Hakosuka Skyline. I felt bad beating it in the car show. It was a realllllllly nice example.
Very nice mate....seen pics of this car before....
Clean the headlights perhaps?????:yes:
I drove through a rainstorm to get to the show. YOu can see people with umbrellas and such, it was a terrible day. Still keeping my eye out for a well priced pair on Xenon Headlights. They are seriously too expensive for f-ing headlights.
