makes a great tone, specially compared to the old cannon. But as you can see leave a great mark on the car. Both stickers have been removed yesterday aswell. Poor girl just needs a wash.
Here is a picture of the front, i need to get aroud to getting some of the paint fixed along with rust in wheel arches. Paint loss on bonnet is from a failed attempt to body wrap it
