judging what a car is by the boot lock is a pretty dumb way to go about things.
every part of the body points to it being a gtr and not to mention it also has a number plate that could only go on a gtr
  • Like 1
So you're meaning to tell me, that there is no absolutely possible way that a gtst could imitate a GTR...? and yeah let's not forget another dead give away, how could I miss it. The number plate that "could only" go on a gtr!
even though my gtst has a gtr wing -it was already installed when i bought the car. i still dont understand why people spend money on making their gts/gtst's look like a gtr, maybe to make it "fully sick"......just buy a f**king gtr
  • 3 weeks later...
Mah I'm more going to be using them as drift wheels anyway. Was just checking so make sure they would fit.
However I have got new wheels & I'm fairly prepared for the hate from people for them.
5ca98e106274ec3088eac3cd9cfe7059_zpsc20d
9acd0b9ac76c68b39b574414f9fd1f70_zps00e3
& just a couple of random pic's.
3cb0e284e4ae66de8980ada64ec03b80_zps5d68
4546f2642984d408ab10ea9c5368c824_zps3041
4b732348af9fdb1be2aadcfa65772751_zpsb1df
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
