Seeing how well the carbon Ztune bonnet with doluck lip fits and lines up. Even though its going on the track car not my gtr. Lines up brilliantly!! only looks off as i didnt latch the bonnet
And a few pics of the track car... although it feels more like im destroying a neat series 2 then making a decent car!
1454594_10153596739625215_360730073_n_zp
1497778_10153596739385215_1380411273_n_z
1460248_10153596739975215_601974365_n_zp
1471395_10153596739800215_800398138_n_zp
1451442_10153596740440215_1458560811_n_z
1457641_10153596740135215_2029707448_n_z
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
