  • Replies 89
Guest INASNT
Originally posted by R31Nismoid
OH SHIT YEAH!!!!
i'm in 100%
By the day i'll be fuel pumped and boosted....
ark my words... i'm going for 260 km/h!
Time to put in my roack shock/spring setup.
Also... i'll get out the ass end of the strip for some doughy practice (ain't even done one before so it'll be interesting  :D)
And yeah. Get onto Motor Mag and organise it.
with the aerodynamics of a r31 u gonna need extra power than us to hit 260. :P
However Linfox owns a racetrack near Anglesea, which is also supposed to be good, if you guys are still up for doing it there, I will go ahead with it.
I am a little confused, is it happening at Anglesea, as everyone is still talking about Avolon.
If at Anglesea what is the distance of the straight?
DATES: I CAN NOT PAY UNTILL I HAVE SOME DATES!
Originally posted by INASNT
with the aerodynamics of a r31 u gonna need extra power than us to hit 260. :D
INASNT: Won't even be in the same leauge as you.. he's already got 190 rwkw at 9 psi.... just fitted a boost controller but fuel pressure was dropping, so new pump, plus 15 psi from TO4, plus full fuel and ignition map and modified VCT shift points.....
hmmmmm..... maybe you'll be needing extra... lol
:P:D:D:D
HA!
i've already got more than you... and i will have at least another 25-30% by that time....
Nark put it best
Originally posted by inark
what inasnt lacks in power he makes up for in his mouth diameter :(
:P
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
