Waz; *politely* S-A-T-A-N-I-C ;) Cheers Bro!
666DAN; would've been more; just need a nice boost controller or someone who knows how to use the Hybrid EBC properly :) then I should be closer to Abo's number!
  • 1 month later...
thought i would list my mods since i have an auto r33
Hks frount mount intercooler
3inch turbo back exhaust with metal hi flow cat
GCG hi flow turbo 450hp
Greddy profec A boost controller
Apexi Safc 2
Apexi Sitc
Bosch 040 fuel pump
Sard Fuel regulator
hks cam gear (not currently installed)
Standard injectors
Z32 AFM
Stock transmission just with tranny cooler
Mv Auto Shift kit (in the process of buying)
I Have had the car for 4 years have considered converting to manual but i have alway's liked the auto. I got car tuned a couple of weeks ago and got 196kw at the wheels before i maxed out my stock AFM on 10.5 pounds. Last week bought a Z32 afm and retuned the car and made 229rwkw on 14psi. but now worried about the transmission since i have already blown one and don't want to kill another so i am hoping the shift kit should be able to cope with the power alright.
It is yet to be run will go to calder when the Mv valve body is in.
wife's daily driver..
s1 r33 4 door
rb25det
acl forged pistons
eagle rods
Jun crank collar
N1 oil pump
new nissan water pump
ARP main, big end, and head studs
full nissan gasket set including head gasket
standard head
standard plenum
standard coilpacks
stainless low mount manifold
gt3582r-iw
custom 3 inch dump
full 3 inch stainless system
ASE FMIC
sard FPR
bosch 044 intank
apexi power fc
q45 AFM
custom 4 inch intake
nismo 550cc injectors
current power is 317kws
with ignition advance average around 18 - 19 degrees
i have been advised that if i drop the boost to say 20 - 22 psi and increase the ignition advance to 21-22 degrees the power should head up towards 330 - 340, without to much pinging.
but thats yet to be proven on my set up.
standard trans
mv stage 2 shift kit
large trans cooler.
Very nice mate ! Are you ever going to have a play with it on the strip ? Would be cool to see what mph it pulls !
What afr's it running top end ?
its near level on 12 afr once on boost.
im planning on dropping that down to about 11.5 afr then pumping some more ignition advance into her.
Hey i would love to stretch her legs down the strip but we dont have one.
bloody government over here are slack, and private enterprise is even worse.
Glad I found this thread... I will add my Datsun 120Y that has a RB20DET auto
Engine has
20thou forgies
Walbro + Bosch 044 & surge tank
GTR ingectors
Stock AFM just before the throttle body
3" exhaust
Garrett GT35R 0.63 exhaust
38mm Turbonetics external gate
Auto has
MV shift kit
MV manual shift controller
B&M pro ratchet shifter
4200 stall converter
trans cooler
185 kw
I could only find my 13.1 @ 113 timeslip from yesterday but it has done a 12.9 @ 113.
Best 60 foot is a 2.25
I use 205x50x16 Toyo R1-R and a 3.7 lsd diff.
I have been told I have the incorrect type of muffler fitted and i need a straight through design.... Damn restrictive V8 muffs.
post-24062-1162824263.jpg post-24062-1162824293.jpg post-24062-1162824441.jpg
Edited by RB120WHY
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
